Go to Post many of the greatest innovation throughout history have come from people who have ignored standard practices and traditional thinking. - jason701802 [more]
  #46   Spotlight this post!
Unread 25-04-2011, 13:22
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Field Electronics
Guess as the the display, 2711P-T7C4D8 list around $3k each...
http://www.ab.com/en/epub/catalogs/1...1114/tab2.html
The AB Ethernet stuff does not use the TCP/IP protocol, it uses AB Ethernet/IP
The Stratix switch will handle the protocol, correctly and is managed, all those etherent blocks are talking, and IGMP managed switch is needed.
Still have not seen what all of this stuff is talking to... If it were me, I would look for a softlogix software on a pc, but being supported by Rockwell, they would probably offer a controllogix plc or even flexlogix plc to control. Their hardware is more robust than their software. . .
The sooner we get behind schedule, the more time we have to catch up.
  #47   Spotlight this post!
Unread 25-04-2011, 14:48
Johnny_5's Avatar
Johnny_5 Johnny_5 is offline
Whose cooking motor?
AKA: Isaac
FRC #3484 (Short Circuit)
Johnny_5 has a spectacular aura aboutJohnny_5 has a spectacular aura about
Yeah, I am aware of the cost of those terminals.
I know that the Stratix handles all of that protocol.
I am pretty sure all of the inputs are talking to the Scorpion Case. I have attached a word document with pictures of the Scorpion Case. I can share with you the FMS software that I have. I think that the stratix is feeding all of the information into the server that runs FMS.
But yet this doesn't make sense because that would mean that there is AB protocol embedded into FMS. Which is possible but it just seems unlikely
  #48   Spotlight this post!
Unread 26-04-2011, 00:21
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
There's another AB PLC inside the Scorpion Case.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
  #49   Spotlight this post!
Unread 26-04-2011, 08:46
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
There is more than one way to skin a cat. If you are looking to exactly replicate the field, renting one is the cheapest solution by far. If you want something to have & can accept close, I would go with somebody like Automation Direct. Would be a lot of work up front, but once done, the year to year changes would most likely be minor.
  #50   Spotlight this post!
Unread 26-04-2011, 09:06
Johnny_5's Avatar
AKA: Isaac
What function does the PLC serve?
  #51   Spotlight this post!
Unread 26-04-2011, 10:30
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Originally Posted by Johnny_5 View Post
jtdowney-
Is there any information you could give to me about the field? Like about equipment used or how things connect together
Not very many details that haven't been shared here already. I would suggest talking to a FTA in your area. You can also volunteer at an event as the FTAA, head scorekeeper, or Field Supervisor, all of those positions have significant interaction with the field equipment.
Spending time as a volunteer around the field has definitely left me with more confidence in the FRC fields and the FTAs who run them.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
  #52   Spotlight this post!
Unread 26-04-2011, 11:18
Racer26 Racer26 is offline
It seems to me that the bulk of what is needed to build a generic (not game-specific) field is some basic networking equipment, a high-end wifi router, 8x 4 digit led displays (3 teams, plus an arena timer per alliance station), and some packet sniffing done between the DS and FMSLight to determine how the communications packets enable/disable/autonomous the robots, followed by some custom software to emulate FMS.
  #53   Spotlight this post!
Unread 26-04-2011, 15:44
Johnny_5's Avatar
AKA: Isaac
To everyone who said it was a secret-
I sent an email a few weeks ago to someone I had known at Rockwell Automation. And then just last week I received a forward notice that my contact had forwarded this message to the Rockwell Automation group that deals directly with FIRST.
Today I got an email from the RA FIRST department with a gif image attached with the layout and basic wiring diagram with how things are hooked together plus a model number and component name for all of the AB components used for the basic scoring system of the field
  #54   Spotlight this post!
Unread 26-04-2011, 16:52
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
I hope you were not representing yourself as someone who had received authorization from the proper channels at FIRST to receive these documents. As for recreating a field completely from photos, instruction manuals, and a list of hardware components you still are biting off a task larger than you are thinking it is. The software that runs the multiple PLC units and firmware on the router are custom and not just regular pieces of software that is available off the web.
I would suggest you take some time and do some research into the old NASA Field that was run by Mike Wade before he passed away. Mike had the desire to have a field that he could truck around the east coast and Mid-Atlantic region of the US to host off season events and pre-ship scrimmages. After researching and working with a real FIRST field he decided it was more work to reinvent the wheel exactly as it was and came up with his own version of the field that did what he needed with a bunch of toggle switches. Albeit this was in the IFI days when dongles were able to be used with the OI's, the same could be done today.
I would suggest running with what has previously suggested, and if you really need a field for more than just some here and there practice, to use a couple switches, routers, a bunch of ethernet cables, and FMS Lite. The stress and cost you will encounter while trying to recreate a FIRST field, will be more than that to rent one if you try to have everything there that is exact as the FIRST fields have.
-Michael Dessingue
  #55   Spotlight this post!
Unread 26-04-2011, 17:45
Johnny_5's Avatar
AKA: Isaac
No, I was not representing anyone but my team when I contacted RA. I have no idea what the proper channels are to gain access to this sort of information. Plus trying to get information like that is not in the spirit of FIRST, if someone were to come and tell me "Your not supposed to have this informationThe PLC unit uses a program developed by RA engineers. The Cisco AP is being used for its exact purpose on the field, and so are the IO units. So the only piece of software I am missing yet it the PLC program.
I have looked into the Mike Wade field, it really looks interesting. But it seems that it would not be very different than our plans. And again all we are doing right now is planning. We are trying to get a feel about how hard this will be. We are trying to tackle all of the hard parts first, the biggest being the electronics to determine if its even possible to do what we want to do.
  #56   Spotlight this post!
Unread 26-04-2011, 20:18
blakeelias's Avatar
blakeelias blakeelias is offline
2011 CT chairman's award
FRC #0694 (Stuypulse)
blakeelias is an unknown quantity at this point
I would be interested in that. How did you get it?
We don't want to build a full field, but simulating the actual FMS would be helpful for debugging our software. Our team has had issues with the FMS not behaving the same as the Driver Station software. (In 2009, during semi-finals at Hartford we didn't move the whole match, because something weird happened with our autonomous code that was different on the actual field: http://www.thebluealliance.com/match/2009ct_sf1m2)
  #57   Spotlight this post!
Unread 26-04-2011, 20:51
Mike o.'s Avatar
Mike o. Mike o. is offline
AKA: Mike O'Brien
FRC #1086 (Blue Cheese)
Mike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud of
Send a message via AIM to Mike o. Send a message via Yahoo to Mike o.
Would you mind sharing this information with the rest of us on this thread?
Mike O'Brien
Founder, Almuni, & Mentor Team 1086
2010 GAL Division Finalist & Coopertition Award; NC Regional Winner & Quality Award; VA Regional Winner & Engineering Inspiration Award Winner
2009 CMP Team Spirit Award; VA Regional Winner & Chairman's Award
2008 VA Regional Winner & Chairman's Award
2007 & 2006 VA Delphi "Driving Tomorrow's Technology" Award
2005 VA Team Spirit Award; 2004 VA Imagery Award; 2003 Rookie Year
  #58   Spotlight this post!
Unread 26-04-2011, 21:03
dag0620 dag0620 is offline
Because we're FiNE
AKA: David Givens
FRC #1071 (Team MAX)
dag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond repute
FMS Lite Download - http://www2.usfirst.org/2009comp/FMS/FMSLight.Setup.msi
User Guide - http://usfirst.org/uploadedFiles/Com...Guide_RevC.pdf
Configuration Guide (for basic hardware) - http://usfirst.org/uploadedFiles/Com...figuration.pdf
David Givens
Alumnus Team Max 1071 ('13) | FIRST Volunteer | NE FIRST
Away making magic for a bit...
  #59   Spotlight this post!
Unread 26-04-2011, 21:27
Johnny_5's Avatar
AKA: Isaac
Attached is just the basic stuff that I have.
Kudos to dag0620 for posting the links to the FMS software links. He was the one who provided them to me as well.
If you are interested in all of information that I have so far it would be so much easier for me to either upload it to a file site or just email it to you, there is a lot of pdf's about radio programming and FTA monitors, audience screens, and setup for almost everything.
  #60   Spotlight this post!
Unread 01-05-2011, 12:02
Johnny_5's Avatar
AKA: Isaac
Any idea who to contact at FIRST to maybe get some information?
