Go to Post Can't engineers be jesters? - danielkitchener [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 28-04-2011, 00:31
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Re: Comming soon: 2CAN Simple Analyzing Monitor
Version 0.6 is here and is a beta version
Updated:
---Fixed silly bug where any value between -9.99 and -0.01 would cause an exception to be thrown (values were read as - 9.99 not -9.99)
---Bundled everything into an executable jar file
---Added a batch file to start the program
---Modified the V-Out scale to show a negative throttle on the graph (note the scale will say 200 instead of 100 - will be fixed in the next release)
Installation notes:
Unpack the zip file into a folder
Modify the driverstation storage ini file:
---open the file
---copy the cmd line
--change to c:\frc\start.bat (or wherever you extracted the zip)
---Paste the command line into a new line on start.bat
**Sorry folks i dont have access to our driver station so I cannot create the line for you. If someone is kind enough to do this and post their line it would be greatly appreciated**
Other notes:
Have not had time to add the logging rate modifier like I had promised. For those without broken promises under hardship may cast the first bit (either a 1 or a 0)
