Encoders and Mecanum Drive
Recently, our team decided to add Digital Encoders into our drivetrain containing mecanum wheels. I was wondering exactly how we go about integrating our encoders into our code. Examples would be much appreciated, but advice is just as good.
Re: Encoders and Mecanum Drive
Be advised of the following: 1) tuning a PID for speed is different from tuning a PID for position (there are some helpful threads on this topic); 2) there are some known issues (FPGA) with the encoder rate computation If all you want to do with the encoders is to make autonomous more accurate, you could consider reading position from the encoders instead of rate. Starting with a sequence of known intermediate stations along a desired vehicle path, compute the rotation for each wheel for each station and close the loop on wheel rotation for each wheel, keeping the command one station ahead of the current vehicle position. You may need to limit the time rate of change of each PID output in order to prevent wheel slipping. The spacing of the stations need not be equidistant. Experiment with the spacing of the stations to get the desired result. Last edited by Ether : 02-05-2011 at 10:13. |
With mechanum, you will need encoders on all four wheels to get an accurate position reference, and you'll have to correct for wheel diameter and the vector of the force applied by the angled rollers. I have some detailed notes from our development this season, and I'll see if I can put together a white paper over the next couple of weeks. There is a bit of slip because of the rollers, but you can get reasonably accurate readings.
http://www.chiefdelphi.com/media/papers/1836 http://www.chiefdelphi.com/media/papers/2390 http://www.chiefdelphi.com/media/papers/2434 Quote:
Thanks! That will definitely help.
-Joe |
#7
I would appreciate a new image. It probably wouldn't be that useful for teams working on their current robot, but for everyone working on new platforms, it would be very nice to have.
#8
Our team would definitely like the new image
#9
I would like the new image as well.
All my encoders are connected to Jaguars, but I do use the semi-period counter functions for SONAR. |
#10
There is a new update posted for LabVIEW... see here. http://www.chiefdelphi.com/forums/sh...2&postcount=71
