Go to Post FIRST isn't about money or robots... it is about people. Take care of that and the rest will follow. - dtengineering [more]
Unread 01-05-2011, 22:25
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
The Frame thread
So, every year, my team makes the same exact frame, just modified for the years game. It weighs too much, and doesn't do a particularly good job of anything. Since I will have a leadership position on the team next year, I've made it one of my major goals to change this. One of my friends came up with this quote:
"The frame should be build to hold the robot; the robot should not be built to put in the frame"
This leaves me with a dilemma: We need the frame done early (that has been one of our biggest shortcomings in years past, not getting the frame welded until the end of week 2). On the other hand, I agree with my friend, which means we can't begin designing the frame until the design is done at the end of week 1.
According to Inventor, the frame weighs a whooping 35 lbs, not counting the supershifters, or the treads. Add those in, and your at 50 or so.
The problem is, we have used the same frame/style of frame for so many years now, our team has pretty much forgotten how to do anything different. So, I thought to myself, this is FIRST, teams like to share information, right? And people like to show off their designs, right? People like to critique designs, right?
I would be very grateful if other teams could show me pictures, or CAD of how they do their frames/drive trains. In return, I will show you and tell you a bit about ours!
We build a lower frame out of 1x1 aluminium T-slot. Very strong, very durable. Very heavy. We sandwich treads between two pieces of those T-slots. The treads are made from fan belts turned inside out and driven with a sproket from the supershifters (last year we used toughboxes). We build an upper frame out of 1/16 aluminum to support various mechanisms. The whole assembly is welded together, and we use T-slot sliders to put many things into the system.
Thanks in advance for other teams' help!
Unread 01-05-2011, 22:49
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Re: The Frame thread
When I look at a FIRST challenge with whatever team I am involved with, I like to have my options open, which is why I am a big fan of a super simple drive type that can be built off of. The T-slots and the extra attachment points seem to make the design you built very modular though, which I like.
Let me get to the point, T-slot is heavy. Switching to a gusseted or welded tube frame will get you to a happy place. If you have sheetmetal options, you can go with that. I also became a fan of the kit frame working with 2702, we built a very solid, and reasonably light drive with it alone (much lighter than what you have quoted). I am sure you can find plenty of pics of the structural tubing design, whether it is a WCD Derivative or something else, they all seem to work pretty well.
I shall provide my take on the tubing frame as well, I have posted this before, but I challenged myself to make a warp resistant (keep welds away from the drive components) gusseted frame that was relatively light. Heavy 254 influence below. This has never been built, but it sums up a lot of peoples ideas.
Probably the big thing I tried to improve with this frame was robot torsional stiffness. By that I mean the frames ability to keep the two drive component rails parallel. The stringers between the drive component rails really help if you don't put a top box on the frame like you have on your design. That is the advantage you have at the expense of weight, nice torsional stiffness.
Look into Team 221 LLC's bearing block tensioning system as well as 254's. They are both good ways of going about things if you choose to go live axel.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Week 2 is reasonable in terms of timeline for welding. Seriously, that's not an issue.
50 lbs of frame might be a bit much, even including drivetrain.
330's traditional frame is welded 1/8" wall aluminum tubing, typically something like a 1"x1.5" or 1"x2" (though we have been known to use 1"x1" with drivetrain stuff mounted on blocks). Sorry, I don't know how much it weighs offhand, but at a guess around 10-20# depending on the year. Quite a lot of teams do something similar; others use the KOP frame for its adaptability and strength.
You could also try modding the West Coast Drive for tank treads. THAT would be interesting--and not all that difficult, I don't think.
Unread 01-05-2011, 22:51
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
The one thing that pops out to me is all the 80-20 in there. Dropping that 80-20 to 1/8" wall aluminum alone would almost definitely shave quite a bit off your weight. We've always used 1" C with corner brackets for our chassis.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 01-05-2011, 23:07
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Here are three diffrent chassis i've made over the year ... 1st one is our new chassis that we will most likely make. 2nd is the type of chassis that we use to use, and probably wont again for a while. and the last one is the same type that 1114 used this year (minus demesions and some fixing up on it).
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 01-05-2011, 23:17
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Having a moving robot for the first time in week 3 is very good. We haven't had one moving in the last two years until sometime at the beggining of week 4. Your current timeline seems fine to me. Except: Your frame may a bit too complex if it takes a week to cut and weld parts. Spending a few days to achieve a simpler solution can save you days in the future.
For this next part, don't think I am saying any of this is wrong, but they are questions you need to answer:
1. Why shift?
2. Why treads?
3. Why T-slot?
4. Why multiple heights of tubing structure?
5. Live vs Dead axle
These are all questions you have to answer for your team. There is no universal best option. The best way to design and build a drivetrain is the way that works for your team.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 01-05-2011, 23:27
M.Wong's Avatar
M.Wong M.Wong is offline
FRC #0503 (Frog Force)
M.Wong is a jewel in the roughM.Wong is a jewel in the roughM.Wong is a jewel in the rough
8020 is incredibly heavy. Even 1/8" thick 1x1 aluminum tubing. For over 5 years, our team has used 1/16" thick, and we've only broken one segment (unguarded, whole section was pushed inward about 3 inches).
If you use 1/16" you can use these Brunner Connectors. They are light and excellent. Just attach a small aluminum gusset with sheetmetal screws to the tubes and you're done.
Unread 01-05-2011, 23:31
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'm curious what exact belts and pulleys you're using. Looks like it would be for a large supercharger.
Unread 01-05-2011, 23:33
M.Wong's Avatar
Also, if you want, I can send the cad files for a very simple drivetrain and chassis that we put together.
Here is a photo:
Unread 01-05-2011, 23:55
dtengineering's Avatar
AKA: Jason Brett
The simplest, most reliable, easiest to fix and cheapest to build drivetrain we ever built was also our best performer.
It took seven years to get to this point... we used composites, the kitbot (which was pretty good actually), TIG welded aluminum tubing (which was better)...
And my favorite was this one, seen here airborne and with its twin.
Jason
Unread 02-05-2011, 00:11
M.Wong's Avatar
Jason
I've always wanted to do this. It goes really well with our Frog Green project, but we just haven't had the time or resources to build something like this during the offseason.
Unread 02-05-2011, 00:26
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
http://www.simbotics.org/media/videos/presentations
If nothing else, you can build a super easy drivetrain like the one above, that is also "better than 90-95% of teams". Certainly better than the tank drive and very simple.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 02-05-2011, 11:23
why is one of the transmissions rotated 90 degrees, would it be in the way of something or is it just something you haven't noticed yet ?
2013-Present
2010-2013
Unread 02-05-2011, 11:41
HighLife's Avatar
HighLife HighLife is offline
FRC #0245 (Adambots)
HighLife will become famous soon enough
Send a message via AIM to HighLife
Kit Chassis and transmissions.
We usually play around with wheel configuration and drive ratios, but our record with the kit chassis speaks for itself.
2 Quality Awards
5 Finalist Awards
4 Championships
1 Trip to Einstein
AdamBots.com- Winner of 7 Best Website Awards!
Unread 02-05-2011, 11:44
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
If it is the same type of tranny as the AM supershifters then by rotating one 90 degrees puts the output shafts at the same level.
1058 PVC Pirates 2016 - xxxx
