Go to Post Oh End-Of-The-World CDenizens... you never fail to entertain... - JesseK [more]
Unread 03-05-2011, 07:39
Re: Battery life?
Kari,
Batteries have a finite life. The batteries we use are speced at 400 charge/discharge cycles under normal use. Our use is pretty heavy with long periods of no use in between. I estimate a team can get realistically no more than 300 if their robots use a lot of current or 350 if they are more efficient. If you are still practicing with 2007 batteries you are getting some decent life.
Unread 03-05-2011, 08:39
fsgond's Avatar
fsgond fsgond is offline
Why aren't you throwing balls?!
AKA: Anthony
FRC #5484 (Memento Vitam)
fsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant future
Re: Battery life?
Our team uses 5-6 batteries changed out after EVERY match. We want our robot to have top performance during every match. We usually have a lot of motors and an air compressor that runs a lot of the match, so our battery is pretty low by the end of the match.
Also we buy all new batteries every year. Batteries from the one year previous are used for practice in the shop and programming and testing the bot in the pit.
Now to the question that you originally asked, I think that you could extend the matches a bit, but no more than 1 or 2 minutes.
Honestly from a field coach position, the matches are very fast, and done before you know it. Also I am not sure that I could take the stress for another minute or two.
