Go to Post Somewhere in New Hampshire at this very moment , the GDC is redesigning the game. - Whippet [more]
Unread 03-05-2011, 10:43
programCurtis programCurtis is offline
programCurtis is an unknown quantity at this point
Laptop Control System
I hoping to build my own robots this summer. I'm very limited on funds so I was wondering if I could use a Dell Inspiron 1150 as the controller. What would I have to do to make this work if it is even feasible.
Unread 03-05-2011, 17:59
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Laptop Control System
This is possible, but you would need still need a few major items:
  • An IO board. See below for more.
  • Speed controllers, relays, etc. Victors and Jaguars work well from any device which can drive hobby servos.
  • Code to control all this. This is largely dependant on the IO device you use.
  • Any hardware, motors, etc.
I've used the following for IO boards.
  • Phidgets(http://phidgets.com). Easy to interface with, but you would probably need 2-3 boards to build an interesting robot. $100+
  • Arduino(http://www.arduino.cc). Inexpensive, with lots of IO options, but not designed to be an IO board. Lots of custom code would be needed. $30+
Eric Haskins KC9JVH
