Go to Post Measure it with a micrometer, mark it with chalk, and cut it with an axe. This is not an exact science. - Jim Meyer [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 07-05-2010, 17:32
Jim Zondag's Avatar
Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
paper: FIRST Championship History Results
Thread created automatically to discuss a document in CD-Media.
FIRST Championship History Results by Jim Zondag
Unread 07-05-2010, 17:34
Phreadumb's Avatar
Phreadumb Phreadumb is offline
FRC 2188 Alumnus
AKA: Dakotah Jones
Phreadumb has a spectacular aura aboutPhreadumb has a spectacular aura about
Re: paper: FIRST Championship History Results
Why does the data on your graph for 1114 start in 2002 if their rookie year was not until 2003?
I will be trekking into territories where FIRST teams do not exist, perhaps I should start one? Oh, but that's a lot of work.
Unread 07-05-2010, 17:46
Jon Jack's Avatar
Jon Jack Jon Jack is online now
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
I see two errors off the bat in the 2009 Archimedes alliance selection:
Alliance 2 was 1503/1538/1649
Alliance 6 was 488/118/343
Team 1538 / The Holy Cows, 2005-2016
Unread 07-05-2010, 20:45
They are shown as 0 prior to 2003. The line just connects the 0 in 2002 to the value in 2003.
Unread 08-05-2010, 07:56
Eric O's Avatar
Eric O Eric O is offline
AKA: Eric O'Brien
FRC #0177 (Bobcat Robotics)
Eric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond repute
Send a message via AIM to Eric O Send a message via Yahoo to Eric O
3 posts and not one Thank You?
Jim,
Thank you for posting this! Although the numbers aren't what matter, it is always fun to look at stats, just like in any other competition/sport.
Any chance you could add 97, 98 and 99 tabs? Not to calculate into your analysis, just so all that information will be in one place.
Thanks again,
Eric
Eric O'Brien
Team 177 - Bobcat Robotics (00-01,06-?)
Team 229 - Division by Zero - Clarkson University (02-05)
Unread 08-05-2010, 08:20
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Thanks Jim for putting this together. Couldn't you have picked a factor that put 33 in the Top 10?
The waiting factor Jim used is pretty neat. If you ask yourself "how much influence should history have"?
For the "team of the decade", it should probably not have a weighting factor, but if you are curious as to the trend, the effect of weighting is very interesting. The 0.66 weighting allows for:
Current: 1
Last year: 0.66
2 years ago: 0.66*0.66=44%
3 years ago: 0.66^3=29%
4 Years ago: 0.66^4=20%
Jim picked this factor as it best followed the "Student cycle" of 4 years. Not only do you loose those students, but you may also loose some really great parent involvement.
This factor also helps up and coming teams like 1625 and 2056 get the respect due to them. For instance 1625 is just 1 ranking position below 33 even though total points over 10 years, they are less than 50%.
The weighting factor is kind of fun to look at. You can play around with different weightings and see the effect. If you go much lower than 50%, then history really has very little to do with the ranking. For example if you had the same result 2 years in a row then scoring would be 1+0.5 which means that last year has less than 33% influence on your current standing.
P.S. Very cute with the color scheme. There is a way to do Tie-die markers if you are interested.
Unread 09-05-2010, 23:06
Phil Ross's Avatar
Phil Ross Phil Ross is offline
Constantly Inspired
FRC #1712 (Dawgma)
Phil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to behold
Send a message via AIM to Phil Ross
very cool. Thanks for posting this database.
FIRST Americorps VISTA, Philadelphia
DAWGMA TEAM 1712: Alumni (2006-2009)
Unread 10-05-2010, 18:30
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Thanks, I saw some data about Team 85 I could not have found on the bluealliance
Unread 10-05-2010, 20:54
Chris's Avatar
Chris Chris is offline
So apparently it hangs......
AKA: Chris Carnevale
FRC #0177
Chris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond repute
Thanks Jim for posting this great data base!!!!
I'd like to throw a shout out to teams 217, 111, 254, 469, 33, 71, and 175, attending Championship 10 years in a row is an accomplishment, never mind making the finals every YEAR OF A DECADE!!!.. Thats an amazing accomplishment...I'm floored...
Thanks again Jim,
Chris C.
Team 151 | Alumni | 2000-2002 | Nashua High School
Team 229 | Alumni | 2003-2006 | Clarkson University
Team 148 | Alumni | 2007 | RackSolutions.com
Team 177 | Engineer | 2008-? |
Unread 11-05-2010, 01:21
akeisic's Avatar
akeisic akeisic is offline
Systems and Strategy Mentor
AKA: Andrew Keisic
FRC #4201 (The Vitruvian Bots)
akeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to all
lol...I guess we're the "Go Big or Go Home" team of FIRST!
2 Elimination appearances...2 World Championships
This sheet is awesome! Thank you for putting in the effort to compile the information. I especially like the weighting factor - it really levels the playing field between "rookies" and vets.
Mentor: FRC 4201 - The Vitruvian Bots
Awards with FRC 294 - Beach Cities Robotics
2014: LA FRC Champions
2012: LA FRC Finalists
2011: San Diego FRC Finalists
2010: San Diego FTC Finalists, San Diego FRC Champions, LA FRC Finalist, FRC World Champions
2009: LA FRC Finalist
2008: San Diego FRC Champions, LA FRC Finalist, LA FTC Champions, LA VCR Champions,
2007: San Diego FRC Finalist, San Diego FTC Champions, FTC World Champions
Unread 11-05-2010, 10:39
Peter Matteson's Avatar
Ambitious but rubbish!
Looking through the data some interesting things struck me.
All 4 #1 seeds have never made it to Einstein, however in 2007 no #1 seeds made Einstein.
2007 Also produced the lowest seed champion with #8, also the only 8 seed to ever advance to Einstein.
In general it looks like 1 and 2 seeds are most successful at advancing from their division.
7 teams have been in 10 consecutive elimination rounds at the championship.
6 Teams now have 2 or more championships during this decade where as only1 team had multiple wins for the first 18 years of FIRST. All multiple champions other than 71 have won their second since 2008.
2 Teams have won back to back championships.
3 Teams have at least 3 consecutive appearances on Einstein.
Teams with multiple trips to Einstein teams that have won are bolded:
6: 177
5: 67, 217
4: 71, 233
3: 25, 60, 111, 175, 254, 469
2: 33, 64, 144, 173, 294, 494, 503, 968, 1114, 1126, 1218
~0.66% of FRC Teams registered each year make the Championship.
~1.26% of all FRC Teams registered this year have made Einstein more than once.
~.678% of all teams ever registered has made Einstein more than once.
58 teams have made Einstein once for a total of 81 unique team numbers appearing in the "Final Four" meaning ~2.39% of all teams have made the final field at some point since the current format for the championship started in 2001.
I'm amazed you able to collect all this great data, thanks for posting it.
Thank-you 294 & 67
www.bobcatrobotics.org
Last edited by Peter Matteson : 11-05-2010 at 17:05. Reason: Added single Einstein stats and corrected percentages.
Unread 03-05-2011, 22:18
Jim Zondag's Avatar
Team Leader
I have updated this championship history database with the 2011 Results.
Congrats to Wildstang for moving into 1st place overall on the weighted history scale.
"To learn what is possible, we must attempt the impossible." Arthur C. Clarke
Unread 04-05-2011, 08:37
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Jim,
Thank you! I alway love looking into this data and trying to determine which team is #1. Congratulations to Wildstang for taking over the title....for this year.
One error I noticed was, in the data for Archimedes you have 2106 instead of 2016.
Also, I am not exactly sure how the weighted data is calculated but we seem to be taking a significant dive in value compared to other past year champions, even though we had similar performances. I guess when you pull ahead by so much, the expectations are that much higher.
Interestingly enough 217 is showing a decline, even though they did better this year than last year. Yet, 469 shows an improvement even though they declined compared to last year.
Interesting, thanks.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
Unread 04-05-2011, 08:38
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Thanks for posting such an interesting database.
I noticed a few mistakes though, it seems that the database has us (816) listed as the 11th pick in the Curie 09 draft, when we were the 6th Alliance Captain. Also I believe the draft position of 1771 is wrong as well. Probably won't change anything, but it caught my eye.
-Dustin Benedict
Unread 04-05-2011, 09:04
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Really nice paper.
I guess 111 is up there in the ranks with 67, 3-time world champs. Congrats again, guys.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
paper: FIRST Drive Trains and Implementation, Championship Conference Presentation Madison Extra Discussion 2 07-05-2008 13:44
paper: Fantasy FIRST: Championship 2007 Jessica Boucher Extra Discussion 0 19-04-2007 00:24
paper: 2006 Niagara FIRST Public Championship Scouting Database Karthik Scouting 17 20-04-2006 19:26
White Paper Discuss: Championship 20004 results for all divisions CD47-Bot Extra Discussion 1 23-04-2004 02:05
