Go to Post IF WildstangIsAwesome = True and SkaIsAwesome THEN Act = AWESOME End IF - Rohith Surampudi [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 04-05-2011, 12:12
Re: Championship 2011 - St Louis - Your Thoughts Please?
Originally Posted by Bill_B View Post
No debris zones? how can that be laid out.
It's kind of tricky--you'd want a 25'+ wide path. 5'+, marked, for people to walk in, with a good, solid 10'+ on either side, running on the most direct route possible. Anybody not in safety glasses needs to stay in the marked area; everybody wearing safety glasses can go wherever they need to.
Looking at the load-in diagram (I don't have a pit map), the run to Curie would run from the corner entrance area around Pit Admin. Ideally, Galileo and Curie pits in that area would be swapped, and the aisle right behind the first aid station would be widened to the minimum distance. Newton would run along the wall (15'+ wide--the wall prevents anything flying from the other side) where the robot route is now up to the end of the practice field, then go straight to the field from there. Where possible, all those paths would go along walls (lower space requirement due to the wall on one side).
