Go to Post The horse is dead; stop beating it please. - DonRotolo [more]
Unread 05-05-2011, 08:28
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: off-season launcher
Originally Posted by Da Kid View Post
Tanis, by the way you answered the questions it seems you have a different set up than we plan.
this is what we are planning to do:
Main tank(120 psi)-->pressure regulators-->A secondary tank for each of the three barrels(different psi's)-->Sprinkler valve-->actual barrels.
Ah, you are correct there. We have one barrel hooked up through a sprinkler valve to our tank. On the other end of the tank we have a compressor with regulators.
Though I am by no means an expert in pneumatics and the underlying physics, I am fairly certain that a pre-charged 5 gallon tank would prove just as problematic. Keep in mind that 120 PSI means 120 pounds of pressure per square inch. As you have 5 gallons worth of volume, you still have far more total stress on the compressor.
I could be wrong there though, so don't quote me!
Team 2052- KnightKrawler
Mentor and volunteer
Unread 05-05-2011, 23:34
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Now, I know you said not to quote you, but I just wanted to clarify something(s). I don't know if this is what you were trying to say, but if it is, then it is just an extension on that.
1) The piston in the compressor has a set (frontal) surface area [which for the sake of simplicity we will say is one square inch]. If the compressor is filling a 1-inch cube to 120 psi, it would need to push with 120 lbs of force to move the piston (1x120=120). Now, if we increase that to 5 gallons, 1x120 still comes out to be 120 lbs. The volume of the tank doesn't change the amount of force needed to push the piston in the compressor. The (frontal) surface area of the piston and the pressure are the only factors involved in this.
2) Volume and surface area are not related in any particular manner, without specifying a specific shape such as a sphere. Thus, the total force applied to a vessel at any given pressure not directly related to the vessels volume, while it is directly related to its surface area.
3) The compressor will still have to do more work to compress a larger volume of air simply due to the fact that more air must be moved, however, at a given pressure, work per compressor cycle (piston stroke) is constant.
