Go to Post Gracious professionalism dictates that if you come to play, I must help you. - Al Skierkiewicz [more]
Unread 03-05-2011, 23:30
Da Kid's Avatar
Da Kid Da Kid is offline
FRC #2957
Da Kid is an unknown quantity at this point
off-season launcher
so now that it's the off-season, our team is building a t-shirt launcher. we plan on having three barrels that do not rotate or anything. i have some questions for the cd community so that our team can make the optimum robot.
1. what is a good diameter for the barrels? I've seen 2, 2 3/8", 3", and even 4"(and also how do you fold the shirt for the size designated)
2. if we wanted a distance of say 100 feet how large would the secondary holding tanks need to be? (we plan on using a sprinkler valve to release the air)
3. what is a good size for the hosing and specifically what is a good way to connect it to the tanks?
4. we plan on pre-loading the main tank to 120 psi with an actual big compressor and recharging between each set of shots with the 2009 compressor. (there is plenty of time for that since the barrels have to be reloaded manually.) would a 5 gallon tank be to big for what we're doing? what would a good size be?
also would the 2010 kop wheels(6wd) be good enough for a high school football game halftime(as far as the softer maybe slightly muddy ground)? what if we made them double wide?
Unread 03-05-2011, 23:56
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: off-season launcher
Here's what I know from 2052's launcher-
1) It has been awhile since I have seen the launcher, but I would guess it is a 3" pipe. We roll the shirts and secure the roll with a rubber band. You can roll a tshirt to just about any size. Play around with it and once you get a method that works, stick to it.
2) This will depend a lot on the individual components. The distance will also depend far more on the PSI than the amount of air you store. 2052's is a 5 gallon tank though.
3) As large as possible. 2052's are I believe 3/4", though bigger is always better in this case. You want to maximize the amount of air leaving the tank at once and you want it to exit as quickly as possible.
4) There are trade offs here. With our 5 gallon tank at about 100 PSI we could get a long shot (over the bleachers from the track on a typical HS football field), a medium shot (middle of the stands), and a short shot (just over a 3ft fence) before recharging. The biggest issue here is the compressor. The KOP compressors are NOT designed for this use. They run VERY hot, and once you get up to around 90PSI, they start cutting out and blowing the circuit breakers. We ran two KOP compressors and still had some troubles. If you can, get a bigger compressor.
As for your last question- we run ours on the track, though I would be wary on the field. Maybe someone else can chime in on that bit.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 04-05-2011, 01:28
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
The KOP compressor is ONLY rated for a 1 gallon tank. We used a 1 gal tank on the robot and the compressor was pushed very hard, though had no problems.
I would definitely get something more powerful.
I have drive the kOP 6 wheel robot over a grass field and it worked fine, though muddy might make it more difficult.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 04-05-2011, 18:39
Da Kid's Avatar
FRC #2957
Tanis, by the way you answered the questions it seems you have a different set up than we plan.
this is what we are planning to do:
Main tank(120 psi)-->pressure regulators-->A secondary tank for each of the three barrels(different psi's)-->Sprinkler valve-->actual barrels.
and we haven't bought anything yet so i am actually asking what would be a good size for the main and secondary tanks for three barrels (there will be plenty of time to recharge after each set of three shots). what has worked for other teams in the past?
and one more question. if the whole system is pre-loaded with an actual compressor to 120 psi and the kop one is just used to top it off is that still too much for the kop compressor?
Unread 04-05-2011, 19:23
NickE's Avatar
NickE NickE is offline
_
Instead of a sprinkler valve, you might be better off with something pressure rated for compressed gases. Sprinkler valves are designed for liquid and if a failure arises, it would likely be catastrophic. For a robot that's going to promote your team in front of people, it's probably better to be safe than sorry.
We're running 6 6" KOP "sticky" wheels on our t-shirt cannon with the center wheel dropped. They work fine on a variety of surfaces.
Unread 04-05-2011, 19:53
IanW's Avatar
IanW IanW is offline
Rookie Mentor
AKA: Ian
FRC #0997 (Spartans)
IanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond repute
While it is certainly better to use components that are rated for air pressure, I found in my own (not too extensive) research that large enough solenoid valves (1" diameter) would be prohibitively expensive for some teams. However, if you know of some source that has such valves for cheap, I would definitely look into it.
And before someone says that an catastrophic failure would also be "prohibitively expensive," I guess that's just something teams will have to consider. I suppose the other option is to just wrap the sprinkler valve in layers (and layers (and layers)) of duct tape.
Unread 04-05-2011, 20:16
Andrew Lawrence
Posts: n/a
If you're looking to build a t-shirt launcher, then why do what everybody else is doing and make a pneumatic canon? Our team decided to try a different strategy, that was both cost effective, crowd-pleasing, and a far shooter! Say hello to the t-shirt SLINGSHOT! Just get some surgical tubing, a long robot, and....BAM! A self-firing, enjoyable, and can shoot more than t-shirts robot! We made ours out of things we found in our robotics room.
Below is the original version (we've been working on it)!
Unread 04-05-2011, 20:28
Da Kid's Avatar
FRC #2957
i agree that a catastrophic explosion would be bad but we plan to put the three barrels inside of a large diameter piece of PVC so even if something does explode it will be contained.
again if someone could chime in on tank sizes(main and secondary) that would be very helpful.
and after looking around i found most of the valves are 24 volt ones. our team isn't the richest(we hope more people will sponsor us one they see this robot) is there a place to get cheap 12 to 24 volt converters. i've looked around and it seems most are around $50 that i've seen.
Unread 05-05-2011, 04:37
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
This is an off season project - why not just run 2 batteries in series? The minibot batteries are 12v each.
Unread 05-05-2011, 07:48
OSU_Springer OSU_Springer is offline
Babcock & Wilcox - Engineer
AKA: Bill Springer
FRC #0677 (Murphy's Outlaws)
OSU_Springer is an unknown quantity at this point
Excellent idea. I would caution that care must be taken here to not then wire the subsequent 24 VDC potential into the PD board. I'm sure that the transformer(s) there would not like the new voltage, nor would the downstream components.
To be safe, I would search places like allied electronics and newark for a 2-turn transformer. This would give you your voltage conversion from 12 VDC to 24 VDC. Just make sure that the transformer is rated for the right power (watts) or amperage, depending on how the spec is written.
Unread 05-05-2011, 08:28
AKA: Bryan
Ah, you are correct there. We have one barrel hooked up through a sprinkler valve to our tank. On the other end of the tank we have a compressor with regulators.
Though I am by no means an expert in pneumatics and the underlying physics, I am fairly certain that a pre-charged 5 gallon tank would prove just as problematic. Keep in mind that 120 PSI means 120 pounds of pressure per square inch. As you have 5 gallons worth of volume, you still have far more total stress on the compressor.
I could be wrong there though, so don't quote me!
Unread 05-05-2011, 08:36
Da Kid's Avatar
FRC #2957
i've searched around and found out that an AC sprinkler valve on a DC circuit can be run on lower voltage since DC isn't as affected by either a resistance or an inductor and thus has more current. 12 volts should be fine.
Unread 05-05-2011, 23:34
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Now, I know you said not to quote you, but I just wanted to clarify something(s). I don't know if this is what you were trying to say, but if it is, then it is just an extension on that.
1) The piston in the compressor has a set (frontal) surface area [which for the sake of simplicity we will say is one square inch]. If the compressor is filling a 1-inch cube to 120 psi, it would need to push with 120 lbs of force to move the piston (1x120=120). Now, if we increase that to 5 gallons, 1x120 still comes out to be 120 lbs. The volume of the tank doesn't change the amount of force needed to push the piston in the compressor. The (frontal) surface area of the piston and the pressure are the only factors involved in this.
2) Volume and surface area are not related in any particular manner, without specifying a specific shape such as a sphere. Thus, the total force applied to a vessel at any given pressure not directly related to the vessels volume, while it is directly related to its surface area.
3) The compressor will still have to do more work to compress a larger volume of air simply due to the fact that more air must be moved, however, at a given pressure, work per compressor cycle (piston stroke) is constant.
Unread 06-05-2011, 00:46
NickE's Avatar
_
A catastrophic failure would be more than expensive. It has the potential to seriously injure team members or spectators regardless of how much duct tape you wrap around it. Is that really a risk you, your team and your school are willing to take to save a few bucks?
Unread 06-05-2011, 01:48
IanW's Avatar
Rookie Mentor
AKA: Ian
Hence why I put "prohibitively expensive" in quotes the second time.
I would still like to know what valve 254 uses - might make my entire point moot.
