#16
Re: off-season launcher
1" NPT MAC Solenoid Valve at ~17.0 cV Flow Capacity with a 23 ms Response Time. For the increased reliability, safety, performance and peace of mind, buying a quality valve was well worth the investment. |
#17
Both of these valves are only rated for 125 PSIG, so be careful not to try climbing above that. The biggest thing with building the air cannon is making sure that you can get an appropriate amount of air into the barrel in as short amount of time as possible. That's why it seems that higher pressures are better. You'll only need a limited amount of pressure if you can get the flow high enough. This of course also depends on your secondary accumulator (tank) volume. Make it too small and you won't have enough air to accelerate the projectile to a proper velocity, make it too large and you are just wasting energy (assuming equal barrel lengths). A note on compressor usage: Do not expect kit compressors to last very long if you are using them constantly. They are surely not rated for anything higher than a 10-15% duty cycle. This means that they are only rated to run at the pressure rating for 10-15% of time. In other words, 6-9 minutes out of every hour. Running them more than that risks overheating the compressor and burning something out. |
#18
There are plenty of stories about and warnings against using PVC to store air, but I have never before heard someone claim that using a sprinkler valve would be dangerous. Sprinkler valves are typically very solid. I wish I had a data sheet on hand for one of them. If someone does, could you read off the ratings? |
#19
Typically solid when used for gardening? I don't understand the argument here. Sprinkler valves are rated for water pressure. A plastic sprinkler valve would likely fail in the exact same way a PVC storage tank would. Use a valve rated for air pressure if you are even remotely concerned with safety. Water is incompressible and behaves completely different than air when pressurized. Please refer to the countless other threads here where this has been discussed before. Bottom-line; please don't cut corners when people’s safety is at risk.
#20
As for "a plastic sprinkler valve would likely fail in the exact same way a PVC storage tank would:" Not true. PVC used as an air storage tank almost always fails at the end caps or connection points, typically due to the a failure in the cement used to join two parts. If it isn't an endpoint, then it's because there was a crack somewhere along the body. If you are operating at reasonable pressures, a PVC tank will not spontaneously explode. I have very carefully watched every thread on CD relating to air cannons and PVC air storage. I would never use PVC to store air. However, you may notice that every single team in those threads intends to use (and many have been using) sprinkler valves. None of them have reported any problems, and no one before has ever called them out on the sprinkler valve. |
#21
The same conclusions drawn about the unintelligent PVC storage tanks should be applied to other points of potential failure. Although I'm not an engineer like Travis, common sense would tell me to just purchase the valve that can handle the pressure well beyond what you will be using. Its not something sensible to cut corners with. +0.02 Last edited by Akash Rastogi : 08-05-2011 at 05:40. |
