#61
Re: paper: Aluminum Falcons (FRC2168) 2011 Scouting System Ver 1.1
Thanks again and please pass our thanks on to your team! |
#63
Ok. Thanks.
#64
Hey guys,
First of all, just wanted to say thanks for your hard work. We've been using your system all year and it has been great. We are planning on using it in the Newton division but the team list is missing team 1732 so we are unable to enter match data for them. Any way to fix that? Thanks again and good luck. |
#65
Updated version with the latest team list (4/25/2011) with 88 Teams per field.
Glad to see people plan to use the system, I will do my best to stop by. Anyone in Curie planning on using it? It looks like we have the other divisions supported. Is there any chance you guys would allow me to have a copy of the data to check out? Thanks. |
#66
This is a great program but we at team1100 have just one question. Is it possable for more than one person to add entries from multiple computers at once then have them all end up on the same sheet? Thanks and see you at battlecry12.
#67
also if you do not mind, team 1100 is looking into using your papers for scouting @ battlecry12 if it does turn out that the answer to my previeous question is yes. once again thanks and see you at bc12
#68
You can copy and paste the data from 2 or more excel files into 1 master sheet. It is fairly easy.
#69
once again thankyou and see you at BC12 |
#70
The system was not designed to have multiple people entering data at one time. However avanboekel is correct that you can copy and paste data into the database page.
Thanks again to all the teams that used the system in St. Louis. It was great to stop by and talk to some of you, I hope it worked well for you. We learned alot this year from putting this together and though we intend to do something even better next year, we'll see what happens. |
