Go to Post We always have a party on Friday. It's called scouting. - Meredith Novak [more]
Unread 01-05-2011, 23:26
wiiking123 wiiking123 is offline
FRC #3855
wiiking123 is an unknown quantity at this point
Encoders and Mecanum Drive
Recently, our team decided to add Digital Encoders into our drivetrain containing mecanum wheels. I was wondering exactly how we go about integrating our encoders into our code. Examples would be much appreciated, but advice is just as good.
Unread 02-05-2011, 09:59
Re: Encoders and Mecanum Drive
Figure out what a reasonable value for maximum wheel speed is for your drivetrain. Scale the encoder rate feedback so it has a range of -1 to +1, where +1 corresponds to that maximum speed. For each of the four wheels, use the existing +/-1 open-loop wheel speed command (from your mecanum inverse kinematic calculation) as the setpoint for a PID, and use the scaled encoder rate for that wheel as the process variable.
Be advised of the following: 1) tuning a PID for speed is different from tuning a PID for position (there are some helpful threads on this topic); 2) there are some known issues (FPGA) with the encoder rate computation
If all you want to do with the encoders is to make autonomous more accurate, you could consider reading position from the encoders instead of rate. Starting with a sequence of known intermediate stations along a desired vehicle path, compute the rotation for each wheel for each station and close the loop on wheel rotation for each wheel, keeping the command one station ahead of the current vehicle position. You may need to limit the time rate of change of each PID output in order to prevent wheel slipping. The spacing of the stations need not be equidistant. Experiment with the spacing of the stations to get the desired result.
Unread 02-05-2011, 14:36
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
With mechanum, you will need encoders on all four wheels to get an accurate position reference, and you'll have to correct for wheel diameter and the vector of the force applied by the angled rollers. I have some detailed notes from our development this season, and I'll see if I can put together a white paper over the next couple of weeks. There is a bit of slip because of the rollers, but you can get reasonably accurate readings.
Unread 02-05-2011, 15:14
You might find the following CD papers useful as you are preparing your notes:
http://www.chiefdelphi.com/media/papers/1836
http://www.chiefdelphi.com/media/papers/2390
http://www.chiefdelphi.com/media/papers/2434
With mechanum ... you'll have to correct for ... the vector of the force applied by the angled rollers.
The inverse kinematic calculation of the wheel speeds takes care of that.
Unread 02-05-2011, 15:22
vhcook's Avatar
Reader of Things
AKA: Victoria
Thanks! That will definitely help.
Unread 06-05-2011, 23:19
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
FYI, Doug found the source of the problem in the FPGA... we are considering releasing a new image that contains a fix for use in the off-season... is that of value to anyone? Or is the current work-around sufficient?
-Joe
Unread 07-05-2011, 12:58
I would appreciate a new image. It probably wouldn't be that useful for teams working on their current robot, but for everyone working on new platforms, it would be very nice to have.
Unread 13-05-2011, 17:22
Ryan Gordon Ryan Gordon is offline
FRC #2854 (EVHS Robotics)
Ryan Gordon is an unknown quantity at this point
-Joe
Our team would definitely like the new image
Unread 07-06-2011, 13:57
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
I would like the new image as well.
All my encoders are connected to Jaguars, but I do use the semi-period counter functions for SONAR.
-- Marshal Horn
Unread 21-06-2011, 16:03
There is a new update posted for LabVIEW... see here. http://www.chiefdelphi.com/forums/sh...2&postcount=71
