Offseason 2012 chassis
As an offseason project, our team is going to prototype a new chassis for future years. this is what i came up with. it takes ideas from all of our best chassis, and best of all it does not require machining at our sponsers. Do you guys have any ideas that could make it better. The wheels will sit on purchased pillow blocks, and the chain from the CimpleBoxes will run directly down to the center wheel
PS. if someone can please load the picture into the forum that would be great. Thanks |
Re: Offseason 2012 chassis
You mention that best of all it does not require machining from your sponsors. My question is, if you have the sponsors and they will/have work with you, why not take advantage of the services and machining that they offer?
The design looks nice and simple. Is there a reason for CIMple boxes instead of toughboxes? Keep at it, looks like a decent start. Add in some supports for your gearboxes though. |
We used toughbox mini's this year, and would have liked speed insted of torque. Because the mounting holes are very similar between the 2, it can be switched at any time. and support for the transmissons will be the bars the come with them the go between the 2.
Really? Witch team used them?
#7
#8
Yeah, they powered our drivetrain.
We had a secondary sprocket reduction from the gearbox to the wheels though, to make our drivetrain have a theoretical top speed of 11.14 fps. ![]() -Nick |
#9
We used CIMple boxes this year for Maccanums ... but they dont have enough torque to turn the wheels for straifing (spelled that wrong). And i believe it would be alot better if you had more torque over speed, because if a team gets in your way it would be easy to push through them, unlike if you only have speed, then you can't.
And Nick did you use 1 transmission per side or 1 per wheel?? I dont beleive we will use CIMple boxes for drive again, but instead use 2-speed Gen 2's, then we have speed or torque depending on what we need ![]() |
#10
It's not a matter of what gearbox you use. It's a matter of what gear ratio you use and what kind of drivetrain you use. You can't just say "CIMple Boxes are bad" when one of you is talking about an 8 inch mecanum drive and another person is talking about a chain-reduced 4" 6WD.
The CIMple Box is a good gearbox for people not interested in direct driving wheels. It packs a lot of reduction into a single gear stage so that you can "finish the job" with your chain reduction. |
#11
Did you have an additional reduction after the Cimple Box? Were you using 6" or 8" Mecanums?
#13
unfortunatly we were direct driving them. this was the first year we tried maccanums, we never even tested with them before. And we were using 6". Another team in Pittsburgh was using 8" Maccanums and they could do everythign fine :$
#14
I suggest you go look at JVN's mechanical design calculator and learn how many options there truly are ratio wise between a motor and wheel. |
#15
-Nick |
