Go to Post Does IR work underwater? Or more importantly, through an air-water interface? ... sigh ... - Rich Kressly [more]
Unread 07-05-2011, 14:32
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Offseason 2012 chassis
As an offseason project, our team is going to prototype a new chassis for future years. this is what i came up with. it takes ideas from all of our best chassis, and best of all it does not require machining at our sponsers. Do you guys have any ideas that could make it better. The wheels will sit on purchased pillow blocks, and the chain from the CimpleBoxes will run directly down to the center wheel
PS. if someone can please load the picture into the forum that would be great.
Thanks
Team 4488 - Mentor 2013-2016
Unread 07-05-2011, 14:36
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Re: Offseason 2012 chassis
You mention that best of all it does not require machining from your sponsors. My question is, if you have the sponsors and they will/have work with you, why not take advantage of the services and machining that they offer?
Unread 07-05-2011, 14:41
Just because you have machining resources, doesn't mean you should make a design to incorporate those machining options. I bet this design would be driving by the middle of week 1 because you can avoid machine time.
The design looks nice and simple. Is there a reason for CIMple boxes instead of toughboxes?
Keep at it, looks like a decent start. Add in some supports for your gearboxes though.
Unread 07-05-2011, 14:48
We used toughbox mini's this year, and would have liked speed insted of torque. Because the mounting holes are very similar between the 2, it can be switched at any time. and support for the transmissons will be the bars the come with them the go between the 2.
Unread 07-05-2011, 14:51
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Originally Posted by Akash Rastogi View Post
Is there a reason for CIMple boxes instead of toughboxes?.
Probably because CIMple boxes gets you on Einstein.
Unread 07-05-2011, 21:27
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Really? Witch team used them?
Unread 07-05-2011, 22:01
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Team 1503 Spartonics.
1058 PVC Pirates 2016 - xxxx
Unread 07-05-2011, 22:07
Andrew Lawrence
Posts: n/a
Originally Posted by sst.thad View Post
The wheels will sit on purchased pillow blocks...
What kind of pillow blocks, and where can someone get these?
Unread 07-05-2011, 22:47
We would either buy them from mcmaster or ace, or if we have the time we could get them machined by our sponsor. because they are separate from the main chassis, we can work on the chassis at the same time, so we do not lose time with the chassis either way. it all depends on if we can find the right ones for sale.
Unread 09-05-2011, 11:05
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Yeah, they powered our drivetrain.
We had a secondary sprocket reduction from the gearbox to the wheels though, to make our drivetrain have a theoretical top speed of 11.14 fps.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 09-05-2011, 11:20
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Thumbs up Re: Offseason 2012 chassis
We used CIMple boxes this year for Maccanums ... but they dont have enough torque to turn the wheels for straifing (spelled that wrong). And i believe it would be alot better if you had more torque over speed, because if a team gets in your way it would be easy to push through them, unlike if you only have speed, then you can't.
And Nick did you use 1 transmission per side or 1 per wheel??
I dont beleive we will use CIMple boxes for drive again, but instead use 2-speed Gen 2's, then we have speed or torque depending on what we need
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 09-05-2011, 11:24
Chris is me's Avatar
AKA: Pinecone
It's not a matter of what gearbox you use. It's a matter of what gear ratio you use and what kind of drivetrain you use. You can't just say "CIMple Boxes are bad" when one of you is talking about an 8 inch mecanum drive and another person is talking about a chain-reduced 4" 6WD.
The CIMple Box is a good gearbox for people not interested in direct driving wheels. It packs a lot of reduction into a single gear stage so that you can "finish the job" with your chain reduction.
Unread 09-05-2011, 11:29
Commander Canada
We used one per side.
-Nick
Unread 09-05-2011, 12:17
Im not saying that CIMple boxes are bad, i'm just saying that they weren't good enough for maccanum drive. They need more torque for what we were using them for (it was just our fault for picking the transmissions)
2013-Present
2010-2013
Unread 09-05-2011, 12:21
Joining the 900 Meme Team
FRC #0079
Did you have an additional reduction after the Cimple Box? Were you using 6" or 8" Mecanums?
