Re: Victors verses Jaguars?
Also, I did put the over-current in the Cons as well... It caught us too much, plus by my understanding, the shunt resistors starts to wear out pretty quickly too, so the Over-current starts to kick in earlier and earlier. Also, to be fair, I believe the Jaguars were design to be used with CAN, and the PWM control was a second-thought. Not a good excuse, but you gain so much functionality with the CAN network. Last edited by RyanN : 07-05-2011 at 20:52. |
In my very limited industry experience, I've seen too much vapor-ware to trust 'functionality' that hasn't been proven...
You can substitute "very limited industry" with "decade-long FIRST" and make the same statement. Unfortunately, FIRST tries to vet too much unproven product. For a $6K price tag (at a very bare minimum), I expect products to work out of the box. |
Also, IIRC you can't run the window motors with jags.
We did, and had no problems.
This is false. Although you -can- run window motors with jaguars, most teams experience serious problems doing so. The reason is that the linear output current of jaguars in conjunction with the torque necessary to turn a window motor engages their locking pins, in turn locking the entire physical system. For more details of just why exactly this happens, I suggest turning to Ether or a mentor who's much better acquainted with this situation than me.
That being said, there are numerous threads regarding the pros and cons of victors and jaguars. It ultimately boils down to reliability v features, respectively. In my two years I've witnessed the death of nary a Victor, and stared in disbelief at a Jaguar shipment with a 60%+ out-of-box failure rate, not to mention a Jaguar going up in magical blue sparks for no good reason (no shorts, no scrap metal debris, no physical damage unless it was from the factory). |
While the newer Jags have gone to lower "ON" resistance FETs, the manufacturer has lowered the number to two in each leg while the Vic remains at three. I think this gives a slight edge to the Vic in terms of dissipation at sustained high currents. No one has mentioned that the Vics are conformal coated. This coating prevents a lot of the contamination that is prevalent with the Jags. Heating of the CIMs over a two hour practice/demo is not unusual. The CIM motors are sealed and intended for intermittent duty. Internal heat has very small paths to dissipate to the outside air. Last edited by Al Skierkiewicz : 09-05-2011 at 07:58. |
#8
personally, i would say avoid jags for any of the high current motors. the cims and rs-775's generate a lot of electrical noise, and this is what we believe to be the culprit behind our CAN problems. the Current control is very nice for some things. i think that a mix of jags and victors would probably be ideal. jags on the smaller motors where more finesse is necessary (550's, 395's) and victors or spikes everywhere else.
another reason to use victors on the high current motors is that they are typicaly in the drive-train, which means that they should have encoders on them already, and if that is the case then the sensing capability of the jag is unneeded. with voltage and speed, current and anything else you want can be calculated. Last edited by Hawiian Cadder : 28-05-2011 at 14:21. |
#9
at CMP another team appeared to be having the same problem ( motor pulsing ) we had already solved the problem with the timeout, and that had helped tremendously, however we were still getting intermittent dropouts in the Can buss. when we talked to the other team (i dont remember name or number, maybe 399?) they said that they had been having the same problem and that attaching a filter capacitor on the leads of their motors had helped tremendously. another thing that lead me to this conclusion, is that we never had any problems with the can while we were testing our lift or manipulator, which were all rs550s or fisher prices. when we tested the drive however, the can network continued to drop out intermittently. the FP on the lift was drawing at least as much current (approx 30 amps continuous) so i was left to think that electrical noise was the culprit. we have not done any tests, but before next season we might try the filter capacitor trick and see if it solves the problem.
#11
971 was testing our elevator, and when we would tell the control loop to move the elevator down a foot, (with a FP, and also with a FP and 775 both running off Black Jaguars), we could reliably get the robot to reset the Jaguars and loose communications. This happened more often when we had lots of D in the control loop. I haven't seen anything like that in the drivetrain with CIMS and Jaguars when doing control loops. |
#12
57 has used CAN for 2 years and we're heading into our 3rd this year. We've had occasional problems with the CAN network dropping out, but I'm pretty certain they were all self-inflicted. Things like the CAN-Serial adapter coming loose from the cRIO, or a finicky terminator that would occasionally short if you looked at it funny. I think CAN is plenty reliable if you're careful about your wiring. The major drawback is that a bad connection will take your whole network down, instead of a single motor.
As for reliability, we've had a handful of the Gray Jags go bad on us, but we haven't lost a black one yet. Again, I think being careful around your electronics is the main thing. The Jags are more susceptible to metal shavings than the Vics, so you need to cover up your electronics if you're producing shavings. Which you should be doing in any case, even if your Vics are less likely to fail because of it. There's plenty of other stuff in the control system that's vulnerable to metal shavings nowadays. |
#14
Ours went bad before the final match of eliminations. That was a pain... |
#15
I'm not trying to start a fight or anything, but your statement represents something that a lot of engineers I work with do, and personally, I hate it. We, as an engineering society, won't get anywhere using the same stuff as we always have. I'm an intern at NASA, and I hate to say I see this all too often. Some things are done the same way as they were done back in the 1960s, and there are much better, easier, and cheaper ways of doing the same thing. It might work for a while, but I'd say replace it once support for that product is up. And sadly, it rarely happens. When that product fails, and there are no replacements, then quick engineering fixes must go into place to mitigate the problem. In this rant, and in all my posts here, I never did say to use CAN. I said it gives a lot more functionality than PWM does. I recommended that teams start to look into it. We tried to use CAN for a few days, and I can personally say that it sucked. It didn't work as intended. It wouldn't work for competition. It had random drop outs. One motor wouldn't work for some reason. A lot of issues. But hey... guess what, it was working. We didn't use it for competition. We used PWM for competition because we couldn't afford to lose a match because the CAN network went down. Now though, we're rebuilding the control system for our 2010 swerve drive robot, and we're going to implement CAN again. This will be a demo robot, and a loss of functionality won't cost us a match here. CAN, or Controller Area Network, is not something new. It has been used in vehicles for over a decade. Every vehicle produced since 1996 (in the US anyway) has been required to include an OBD-II port. Part of the OBD-II's specification is CAN, along with a few other protocols, but as of 2008, the CAN protocol is required. Also, much of the vehicles equipment talks with CAN. With my car (2006 Mazda3), the stereo talks with the ECU to get the trip computer information over CAN. CAN is tried and trusted in the industry. So don't put the blame on CAN. (Source: http://en.wikipedia.org/wiki/On-board_diagnostics) The issues that arrise are with the Jaguars and the cRIO images and our own software. There has been a steady release of updates, resolving most of the issues with CAN. Our team is taking the initiative to try to iron out some of the remaining bugs. Out of the 40 or so Victor 884s we've had, we've probably blown 10 of them. Now out of the 10 or so Jaguars we have, we've burnt out just 2 of them. That's nearly the same failure rate. The difference though is that we know that most the Victors failed due to user error, whether it be metal shavings or pushing the robot too fast while off. The Jaguars failed because of a manufacturing defect (Gray). Also to note about the Window motors & Jaguars... Removing the locking pins seem to help most people. http://wiki.team1640.com/index.php?t...r_Locking_Pins http://www.chiefdelphi.com/forums/sh...ad.php?t=83973 As part of our 2010 robot, we have the Window motors for steering, and we're planning on trying to use the CAN network for better control using the voltage mode. I'll report if I have any problems later this summer if we have any. I will be removing the locking pins. The only difference I can see between the Jaguars and Victors is the frequency at which power is sent to the motors. The Victors 'refresh' the power slower than the Jaguars. This can change the way the thermal cutout works. Remember that window motors are designed to run at either -100%, 0%, or 100%, not anything in between. We're using these motors outside of their intended purpose. |
