Go to Post Time to iterate, more. - jwfoss [more]
Unread 08-05-2011, 01:43
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: off-season launcher
Originally Posted by Travis Covington View Post
Typically solid when used for gardening? I don't understand the argument here. Sprinkler valves are rated for water pressure. A plastic sprinkler valve would likely fail in the exact same way a PVC storage tank would. Use a valve rated for air pressure if you are even remotely concerned with safety. Water is incompressible and behaves completely different than air when pressurized. Please refer to the countless other threads here where this has been discussed before. Bottom-line; please don't cut corners when people’s safety is at risk.
Yes, they are rated for water pressure. That doesn't mean that they are at a high risk for failure when using air. It simply means that they need to be tested before being used with compressed air.
As for "a plastic sprinkler valve would likely fail in the exact same way a PVC storage tank would:" Not true. PVC used as an air storage tank almost always fails at the end caps or connection points, typically due to the a failure in the cement used to join two parts. If it isn't an endpoint, then it's because there was a crack somewhere along the body. If you are operating at reasonable pressures, a PVC tank will not spontaneously explode.
I have very carefully watched every thread on CD relating to air cannons and PVC air storage. I would never use PVC to store air. However, you may notice that every single team in those threads intends to use (and many have been using) sprinkler valves. None of them have reported any problems, and no one before has ever called them out on the sprinkler valve.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 08-05-2011, 04:37
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
I still encourage you to do further research before using a sprinkler valve. While there may not be any documented failures that you have found thus far, the associated risks should not be taken lightly. Explaining in near absolutes how something will not fail is not helping your case here, either. I do not believe you know how all PVC storage tanks fail, and also do not believe you know all of the failure modes of a sprinkler valve. Objectivity is key, and building something safe which your school, students, and team can be certain won't harm anyone is my only concern. I posted initially because it seems like many people on these forums are not taking the safety of these cannons seriously. Please do not take my posts as personal attacks, because they are far from that. Using internet forums, youtube videos, and tech blogs to determine the safety of processes, mechanisms, materials, and hardware scares me and I hate seeing corners being cut with regard to safety in an effort to save a few bucks. Please just be as cautious as you can when proceeding.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 08-05-2011, 05:31
Why go through haphazard testing on a component's limits while another product is already rated by the company's engineers through rigorous testing and with a high safety factor to perform the exact same task in a safe manner? It would be like testing the limits of 150 pound strength steel cable and because under my own tests I see it is fit to lift 170 pounds of material instead of purchasing something rated at 175 pounds or 200.
The same conclusions drawn about the unintelligent PVC storage tanks should be applied to other points of potential failure. Although I'm not an engineer like Travis, common sense would tell me to just purchase the valve that can handle the pressure well beyond what you will be using. Its not something sensible to cut corners with.
+0.02
