Thread Tools |
Rating:
Display Modes |
Re: Broken 360 controller needs a dead zone
Creating a deadzone should be fairly easy. I would use a select VI. To feed the selector I would run the input through an absolute value then a "greater than" VI. For the True part of the Select VI you would have the unaltered input value and for the False you would feed 0.
EDIT: Alternative suggestion removed due to Chris' post below. Last edited by Vikesrock : 08-05-2011 at 21:34. |
It's generally good practice to add dead zones to Xbox 360 controllers. They don't consistently return to any particular center point.
Well yeah I guess it works fine with all my games except fallout 3 for some reason and minecraft on my computer. Those and my program are the only things it leans right on
What I'd do is use the in range and coerce function, and then either return zero or the value with a select. Remember to do it for each axis.
Videogames like Fallout, Deadly Premonition, etc, didnīt manage the dead zone at all, so if your controller is slightly "broken"... well, s**t happens. Itīs a very common issue with the Xbox360 controller, if you are too rough playing (but there are FEW titles which donīt manage the dead zone, so chances that you never notice your controller is broken are high). New and well conserved controllers work fine, so if you are not able to manage the dead zone, you can always buy a new one... |
I've noticed this on our 360 controllers, and for this reason I will encourage our team to use something like this as an FRC gamepad in the future.
#7
If drivers werenīt a problem, this would be nice:
![]() So beautiful... Itīs for a "mecha (giant robot of massive destruction) simulator" for the Xbox1, Steel Battalion. And back to the real world... if you dont like the 360īs just try Logitech gamepads, those are fine too. |
