Go to Post Dance Dance Revolution is the only solution. That rhymed. I should not be on chief at this hour of the morning. >_< - Eugenia Gabrielov [more]
Unread 08-05-2011, 23:20
Chris is me's Avatar
AKA: Pinecone
Re: Swerve Drive Modules
There is no way that you would be able to bend that module in one piece.
Unread 08-05-2011, 23:21
42!'s Avatar
42! 42! is offline
College Student
42! is an unknown quantity at this point
What method are you using to hold The output shaft to keep the module standing straight? This tends to be one of the more important things to get right in swerve drive. As it is i don't see any method in place to hold the module against side force.
Unread 08-05-2011, 23:27
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
I'm not sure what you mean. The output shaft infers the bolt holding the wheel/sprocket, correct? What do you suggest I add to prevent unwanted sheet-metal bending?
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 08-05-2011, 23:32
42!'s Avatar
42! 42! is offline
College Student
I was actually referring to the shaft that the whole module pivots on, as it it i see it being held by one bearing at the top of the module, normally teams will have a second shaft around the drive shaft that the module turns on. Then this shaft can be held by some sort of bearing system that attaches to the robot.
Unread 08-05-2011, 23:51
AKA: Mathew Simon
Okay. Well, yes, in this design it is effectively held by one bearing. Where exactly do they place that second shaft? I can also, of course, just change it to a roller bearing, which are longer.
Mathew Simon
CAD/Design
Unread 09-05-2011, 00:03
42!'s Avatar
42! 42! is offline
College Student
The drive shaft is placed in the center of the shaft the module rotates on. In most systems there are two bearings hold the drive shaft. There should also be a system to hold the shaft the module pivots on. if your confused about this you should look at 221's Swerve system Revolution swerve http://www.andymark.com/ProductDetai...ctCode=am-0760
They have one of the more reliable swerve systems around
Unread 09-05-2011, 00:40
akeisic's Avatar
akeisic akeisic is offline
Systems and Strategy Mentor
AKA: Andrew Keisic
FRC #4201 (The Vitruvian Bots)
akeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to all
Guess what team choose NOT to use a swerve drive this year? Wildstang! And it's practically been there signature for years.
It's typically about what goes on top of the drive train that makes the difference. Glad to see you're working the details BEFORE the season starts.
Mentor: FRC 4201 - The Vitruvian Bots
Awards with FRC 294 - Beach Cities Robotics
2014: LA FRC Champions
2012: LA FRC Finalists
2011: San Diego FRC Finalists
2010: San Diego FTC Finalists, San Diego FRC Champions, LA FRC Finalist, FRC World Champions
2009: LA FRC Finalist
2008: San Diego FRC Champions, LA FRC Finalist, LA FTC Champions, LA VCR Champions,
2007: San Diego FRC Finalist, San Diego FTC Champions, FTC World Champions
Unread 10-05-2011, 11:44
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
Has anyone ever build a two wheel swerve drive with omni's on the corners? Make the swerve wheels 2 or 3 inch wide on the center.
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
Unread 10-05-2011, 12:00
Joining the 900 Meme Team
FRC #0079
I seem to remember a team doing something like that in 2008, can't name the team though. I would be careful about making the wheels 2/3 inches wide because the wider grippier wheels make rotating the modules more difficult.
Unread 10-05-2011, 12:02
Gdeaver Gdeaver is online now
FRC #1640
The current design shows several problems. It is not easy to make a module that can hold up to some serious stress. We have done swerve for 2 years now and this link will show a design that has proven very durable.
http://wiki.team1640.com/index.php?t...II_Drive_Train
It's only May. You have several months to refine the design.
Unread 10-05-2011, 12:31
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Originally Posted by msimon785 View Post
@AdamHeard, yes we did. I'm going to do my best to get our team away from Mecanum drive.
What trouble did you have with Mecanum drive? We did direct-drive mecs from AM nanotubes and had our most reliable, successful drivetrain in 7 years.
Hi!
Unread 10-05-2011, 19:57
Ryan Himmelblau Ryan Himmelblau is offline
FRC #0111 (Wildstang)
Ryan Himmelblau is an unknown quantity at this point
The reason we chose 6wd this year was purely based off our strategy for this year's game. We deemed early in the build season that for this year, speed was far more important than maneuverability.
Every drive system has it's advantages and disadvantages. You should base your drive train decision off what will complete the task at hand the best, not on what is cool or different or easy.
During our initial brainstorming seasons we had at one time 8 different drive systems up that we were considering. Hooray for double sided white boards!
Unread 10-05-2011, 20:40
AKA: Mathew Simon
We were selected to be on an alliance by Teams 1717 and 330 (seeds 1, 3. obviously both powerhouses). We competed well in the first 2 matches of QF. After that, our bearings on the AndyMark Mecs shot out one at a time. 3 or 4 matches later, after the second SF match, we had no working wheels and were dropped from the Alliance. Sure we could have put in better quality McMaster bearings (that's what we did before the next regional, Denver), but it was still more than frustrating.
Mathew Simon
CAD/Design
Unread 10-05-2011, 21:22
Did that fix the problem? Were there some other issues beside that?
Unread 10-05-2011, 23:57
AKA: Mathew Simon
Yes. It fixed the problem, at least for the most part. When it gets down to the root of the problem, though, we had welding displacement and inaccuracies which inevitably caused a misalignment of chain, and thus an unnecessary torsion force on the bearings.
Mathew Simon
CAD/Design
