Go to Post There are times when your team will struggle and there are times when it will achieve great victories. There will be times when unknown and uncontrollable factors will intercede to provide an unexpected outcome for which your team must compensate. - Travis Hoffman [more]
Unread 06-05-2011, 23:24
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Omni Directional movement for tank drive.
after observing the competition at saint Louis, and how tank drives were far superior in most respects this game, i remembered something Ive read about called melty brain.
the idea is to have a tank drive robot, that spins very quickly. by altering the amount of power to each side at different angles within a spin. omni-directional movement is achieved. a standard 2 speed tank drive should be able to spin fast enough to make this work ( to some degree) in a fast gear.
this type of movement has one big advantage that i can see, a very intimidating defensive robot. because of all of the added energy stored in the robot, even a robot with tank treads would have a difficult time passing a defender with this type of drive-train. especially if it could move in any direction.
http://www.spambutcher.com/meltyb.html
all of the open source software can be viewed above.
my question is, how do you think this would work in a match, would it be legal, and how tough would the spinning robot need to be. would it pose a danger to other robots on the field. ( the goal is to intimidate, not actually destroy) if the answer to the last question is yes, what is a reasonable speed to spin. ( our robot this year with 6 wheel tank, powered omni wheels on the ends, could spin approx 4 times per second.)
also what other potential does this type of control scheme have in FIRST. if it werent for the trailers i think it would have been THE best drivetrain for 2009. and it would have been an intimidating contender for a simple omni directional drive that rookie teams could pull off. ( direct driving 8 inch wheels from cimpleboxes) without buying ANY additional hardware.
Last edited by Hawiian Cadder : 07-05-2011 at 11:32. Reason: whoops, posted wrong link.
Unread 07-05-2011, 01:34
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: Omni Directional movement for tank drive.
So, the idea of this robot is to scare the other teams into not making contact with your robot because they know it will cause damage to their robot?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 07-05-2011, 02:30
AKA: Isaak
Team Role: CAD
no. the idea is to achieve omni directional movement. defense would be one possible use, however it cannot hold more energy than the same robot traveling at its top speed. the goal of this would be to make a robot more difficult to push. in past years teams without any predictable means of scoring have had the ability to simply defend. however when more teams than ever have multi speed gearboxes, adjustable stances, and other methods of altering their drive to serve to score swiftly as well as push through defense, this is no longer really a viable option. having a spinning robot removes traction and torque from the factors that influence how difficult it is to push another robot. this is a way to increase defensive ability, without adding any significant complexity such as gyros or legs. the intent would not be to damage any robot, but to make an omni directional robot very simple mechanically, and to gain an edge defensively. because the robot is always spinning it always holds the same amount of kinetic energy as it would going in a straight line. in battle bots the spinner bots typicaly spin more than 1000 rpm. i was thinking more like 120 - 360 rpm.
Unread 07-05-2011, 03:11
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Is it called melty brain because your programmers are going to go insane testing and debugging it?
Seems like it would be useful to have on the field, however, it could also be pretty clumsy and inefficient.
Unread 07-05-2011, 11:32
AKA: Isaak
Team Role: CAD
i fixed the link, now you can actually see the project.
Unread 07-05-2011, 12:55
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Originally Posted by Hawiian Cadder View Post
The goal of this would be to make a robot more difficult to push.
I'm lost. Can you explain how this robot would be more difficult to push?
Unread 07-05-2011, 14:49
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Isn't the rate of "linear" motion related to the rate of rotation in this design? So wouldn't slowing down that rotation, in turn, slow down how quickly you "move" around the field?
I also question the safety of this design on the FRC scale. Even if you keep the design relatively compact (say 18"x18" without bumpers) and rotate at the bottom end of your suggested range (120rpm), the outside corners of your bumpers are already moving faster than 1000 ft/second. Much worse are the hard corners of your frame (which are traveling 800 ft/second). There's a reason that videos like this one give warnings about "melty-bots" being able to kill you if they're out of control. There's a reason why these types of robots are mostly seen in robot fighting, because their very functionality relies on large amount of kinetic energy.
Unread 07-05-2011, 15:48
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Our team has a running joke of inventing "mecanum treads".
Unread 07-05-2011, 16:09
AdamHeard's Avatar
Lead Mentor
The common difficult issue for "melty brain" designs is a reliable heading indicator. If the robot doesn't accurately know where it is at least once per cycle, it can't accurately translate.
Even fully functional melty brain designs achieve rotating translation speeds that are very slow compared to the vehicle purely translating. It would be an incredibly easy robot to just juke around.
Unread 09-05-2011, 13:15
JohnFogarty's Avatar
AKA: @doctorfogarty
Mauler 5150 v.s. Jabberwocky
Battlebots Televised version.
Watch what happens.
P.S.(I am totally not posting that because my mentor drove the winning robot) noo....why would I do that.)
John Fogarty
Unread 09-05-2011, 14:12
AdamHeard's Avatar
Lead Mentor
Watch what happens.
I don't see the relevance here. I'm pretty certain Mauler was a shell spinner, and had a traditional skid steer drive inside.
Unread 09-05-2011, 15:13
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
It's an interesting concept for driving, but I'm pretty sure the mechanisms team would stage a coup after their end effector fell of for the umpteenth time due to excessive stresses on the joints.
GitHub
Unread 09-05-2011, 15:18
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Um.... I think we might have done that at the VEX level
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 10-05-2011, 21:19
SamM SamM is offline
FRC #5842 (Royal Robotics)
SamM is just really niceSamM is just really niceSamM is just really niceSamM is just really niceSamM is just really nice
Though your numbers are off by an order of magnitude or two, you are right in theory. It would be much faster to just turn a tank robot and drive in the desired direction than it would be to wait for the robot to "drift" in that direction.
There's actually a robot with these in one of the labs here at the University of South Florida. I believe a master's student designed it for his thesis a few years back. I'll see if I can get a picture next time I'm there.
"The universe is probably littered with the one-planet graves of cultures which made the sensible economic decision that there's no good reason to go into space--each discovered, studied, and remembered by the ones who made the irrational decision." -Randall Munroe, XKCD
Unread 10-05-2011, 22:45
RoboDesigners's Avatar
RoboDesigners RoboDesigners is offline
VRC #2190 (RoboDesigners)
RoboDesigners will become famous soon enoughRoboDesigners will become famous soon enough
At VEX level:
http://www.vexforum.com/showpost.php...1&postcount=19
http://polynomic3d.com/user/smith/Mechanum.png <- That's VEX tread wrapped around a sprocket...
Visit my website! www.RoboDesigners.com
VRC Team #2190
Twitter: @RoboDesigners
