Re: Perfect Drive?
Re: Perfect Drive?
JVN worked up an Excel spreadsheet drivetrain calculator years ago. It makes some basic assumptions about the physics to estimate the required torque to turn a skid-steer robot. Then it matches it to the motor curves to determine amps. It's not 100% accurate, but it's a good rule of thumb. Especially if it's telling you you're pulling 110 amps in a turn. I'll grant that that's probably an over estimate, since it doesn't account for pesky realities like the battery's internal resistance dropping your volts from 12 to 8 under a 400 amp load.
@MattC, Unless you've screwed up the settings on the wheelbase dimensions, that's a good indicator that you're geared too fast. I'm assuming you're working off 8" wheels, in which case that's something like a 20 fps robot you've got there. That's insanely fast. It's been a few years since we've done a skid steer, so I don't have a great feel for the appropriate top speed, but that seems excessive. You're going to end up with a lack of torque and the huge current draws in turns like you're seeing. I'd think about dropping the gear ratio a hair to get more torque so you're not beating your batteries quite so close to death. Also recall that a competition robot is 120 lbs dry weight. Bumpers and a battery add another 20-25 lbs, which is going to increase your current draw even more. |
Re: Perfect Drive?
Another thing to consider: Machinability with the resources available to your team. An extra week of driving practice and shakedown outweighs a lot of ooo-shiny. |
Re: Perfect Drive?
Re: Perfect Drive?
@Matt: Is that how you got 102 amps? You used JVN's spreadsheet to calculate amps for a skid-steer turn? |
Re: Perfect Drive?
Yes, I used JVN's spreadsheet to get my numbers.
@kevin I'm running my numbers on 6in wheels. I am at 13fps, if i saw 20, i would know somethings wrong. @Ether I did run these numbers trough his spreadsheet to get 102amps. I did use it to calculate for a skid-steer, and i'm scening it wasn't men't for this? And this is why i asked if 102 was to much, it sounded a little high to me, because the jags have a 40amp cut off. @bill This is why I'm starting with the raw needs then building from here. Last edited by MattC9 : 10-05-2011 at 22:25. Reason: for got one thing |
#7
Re: Perfect Drive?
13 feet/sec vehicle speed, 8.6:1 gear ratio from CIM rpm to wheel rpm, 6" diameter wheels, 90% gear plus sprocket efficiency:
13 feet/sec vehicle speed 8.6 gear ratio from motor to wheel 6 inch diameter wheels 90% power efficiency of gearbox and sprocket 18.85 vehicle inches per wheel rev 156.00 in/sec vehicle speed 8.28 wheel rev/sec 496.56 wheel rpm 4270.45 motor rpm 67.30 oz-in CIM motor torque @ 4270 motor rpm 520.90 oz-in wheel torque 173.63 oz wheel force 10.85 lbs wheel force 43.41 lbs for 4 wheels Does that sound right? |
#8
Re: Perfect Drive?
I'm attaching some screen shots of my numbers to this post so you can look at them 1st hand.
#9
Re: Perfect Drive?
Also, the 102 amps appears to be the motor torque required to break traction, and is driven by the "Contact Coef of Friction". John, if you are lurking, could you please shed some light on what are the physical contributors to this "Speed Loss Constant"? The only thing I can think of off-hand would be the rolling friction and the friction in the wheel bearings, since all the drivetrain friction should already be included in the "Drivetrain Efficiency" number, n'est-ce pas? |
#10
Re: Perfect Drive?
Re: Perfect Drive?
Re: Perfect Drive?
On 968, over the years we experimentally determined that about 17 ft/sec is pretty much the upper limit for 4-CIMs playing most games on the standard size field. Anything over that and the acceleration just really seems to drop off (I base this on no math, but just what it felt like from a driver's perspective). In 2008 for Overdrive, we were geared up around 20 ft/sec, but it had the Fisher Price motors in there too. That thing was a real blast to go hauling around the oval track. If I recall, we were getting in the range of 8-second laps around the field. But, we had very well refined cornering code that let us carry the speed through a nice arc around the divider. When we pulled out the Fisher Price motors to use on another mechanism, it got noticeably slower. Also, we started burning out CIMs, even just in 2-minute matches.
