Go to Post We need to find the female engineering mentors in FIRST and start having them present/co-present technical conferences at the championships. We need to start showing the girls on the teams that there are female engineering "rock stars" to look up to. - Kims Robot [more]
Unread 11-05-2011, 13:15
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: pic: LabVIEW Code that Crashes
I see a problem with how your accessing your array elements. Arrays start at 0, and go to n-1, where n is the number of elements. LabVIEW, however, is usually good about handling these kind of problems and not crashing, but it all depends on what your default 'out of bounds' value is. If it's blank, then you might be trying to drive the wrong motor. In any case, reducing all your array elements by 1 should fix it.
So 3 will be 2. 2 will be 1, and 1 will be 0.
I noticed that you misspelled rightMotor in the 3rd array element. Since it's a ring constant, the spelling doesn't matter, but for future reference, take note in how you spell things, as it can, and will break your code (our programmers did this a lot this year).
Everything else that I see looks good. Let me know how that works.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 12-05-2011, 10:15
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Thanks, but the problem was solved when we switched back to RobotC - I appreciate the effort, though, and I'll try that when I get the chance to reimage the NXT.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 12-05-2011, 11:38
Ethan -
Ryan is correct. The issue is that you are attempting to look at an element that doesn't exist.
Out of curiosity - why are you using an array? Wouldn't it be easier to use the elements directly?
