Go to Post Have we all said "thank you for all you do" lately? :) - RoboMom [more]
Unread 12-05-2011, 08:22
Jared Russell's Avatar
Taking a year (mostly) off
Re: Problems That Arise and Things You Want
That's a good question. Since it is not an explicitly permitted motor modifcation via <R47>, my guess would be "no", you may not remove the sheath (under 2011 rules).
Unread 12-05-2011, 09:36
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
The smaller WACO connectors need to be modified, they are hard to attach wires to and then plug them in so that they stay. I do agree with the need for gear boxes for the small motors, as a small team we can not afford to purchse them from andy mark each year. volume or direction controled air valves would be nice so we can control the pnematics leagally. Linear drive boxes would be great. Rack and pinion gear box to fit the motors we get with the KOP. Mounting boxes or hardware designed for the sensors as ours do not last long and eather get damaged or just quit working. A better mount and wiring system for limit switches. Addapters for the fisher price gear boxes like we use to get with the KOP.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 12-05-2011, 11:28
Are you referring to the white Wago 734-102 connectors? We never have problems with those, unless you count losing track of the proper tool for opening them. You just need to use the right wire (stranded, 14-22 AWG) and strip it to the proper length (7 mm).
Unread 12-05-2011, 13:10
czeke czeke is offline
Tool and Die maker/Tool Designer
AKA: Carl Zechel
FRC #1091 (Oriole Assault)
czeke has a spectacular aura aboutczeke has a spectacular aura about
A modular system of shelving that permits quick access to standard size parts storage containers without having to unstack the totes sitting on top of the one you really want. One that permits a team to integrate them into their pit in a variety of configurations (8 high x 1 wide, 4 high x 2 wide, etc.)
Check out the one from Stanley ( can be purchased at Wal-Mart ). The comparments have 3 different sizes and are made interchangeable. You can move them around, since they are individual containers.
Unread 12-05-2011, 14:24
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Originally Posted by Travis Hoffman View Post
Ratcheting T-handle allen wrench set with interchangeable hex keys?
They already have one: Rogue Tool http://www.garrettwade.com/hex-ratchet-imp/p/76B03.01/
You can find them cheaper on eBay, though.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
