Go to Post the whole process is the most valuable part, not the award itself - Rich Kressly [more]
Unread 12-05-2011, 23:05
Andrew Lawrence
Posts: n/a
Using plaction wheels on a roller claw
Our team is working on our robot again, and we're thinking about changing our manipulator to a roller claw. We want a design with wheels the have a major grip advantage over other wheels, and though about using small plaction wheels on our roller claw. What we would like to know is, do you think this is effective? Does anybody have any suggestions on wheels? We want to be able to use our manipulator to both suck in tubes from the floor, and spit them out a few feet. We want to spit them out in a possible close-range feeding strategy.
Thanks!
Unread 12-05-2011, 23:40
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: Using plaction wheels on a roller claw
Vex wheels!
We used them...worked great.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 13-05-2011, 00:12
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Thanks!
Mcmaster offers both Urethane and Neopreme drive rollers in all sorts of sizes. They seem like a very viable option.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 13-05-2011, 01:17
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
We used 3" diameter Tetrix wheels. Also for a less expensive alternative (that works pretty well) try this:
http://banebots.com/c/WHB
Unread 13-05-2011, 03:15
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
We used polycord for the actual grip on the tube, but for the initial contact surface we used banebots wheels. They wore a little bit, but they got even more grippy as they wore down. We were extremely pleased with how they performed.
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 13-05-2011, 03:35
Dominator1619's Avatar
Dominator1619 Dominator1619 is offline
FRC #0313 (Bionic Zebras)
Dominator1619 is an unknown quantity at this point
I know the name isn't a popular one anymore, but banebots has wheels with more than enough grip to do the job. We used the blue 2 7/8" ones with a .500 diameter shaft. Work wonderfully once we got our second gearbox ( we ordered everything we got from them separate so we'd have at least most of the roller components ).
So where is this cake I was promised?
Unread 13-05-2011, 03:51
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
A problem with the plaction wheels is that is a lot of weight you are putting on the end of your manipulator. I would recommend using a piece of pvc with whatever tread you choose riveted on and if you decide to go with polycord in your claw you can use the tread to space out the polycord. We have done it this way on our bot this year and our bot from 09 but this year we used solid aluminum rod which is overkill when looking back on it. We also used the 1 inch pulley diameter polycord this year and while it worked fine I wouldn't recommend it becaue it has some issues with breaking while the two inch pulley diameter stuff never broke in our history of using it.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 13-05-2011, 06:45
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Speaking as the main designer on 694's claw, the setup we had was wonderful, but the spaghetti polycord was a last resort. We probably would have done way better with flat polycord.
With plaction wheels you need to make sure that your floor acquiring angle is high enough so that the tubes don't just get pushed around by the bottom wheel, because they won't be pulled up unless both wheels are in contact. Also, if you want to hang over the ubertube, those big wheels might create an obstacle.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 13-05-2011, 08:08
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I'd recommend using Banebots wheels: http://banebots.com/c/WHB
They're cheap, robust, easy to drive (1/2" Hex) and come in a variety of diameters.
-Dustin Benedict
Unread 13-05-2011, 09:06
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
We used urethane wheels from McMaster. They were really grippy and picked up the tubes very quickly.
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 13-05-2011, 09:14
Brandon Holley's Avatar
Thirding the call for banebots wheels. Cheap, light, grippy, variety of mounting configurations...should work well for just about any variety of roller claw your going for.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 13-05-2011, 09:18
Andrew Lawrence
Posts: n/a
We were planning on using the small wheels if we did use plaction. However, there is still all of these ideas I'm seeing! I hear a lot about the banebots wheels, and the Urathane wheels from McMaster. The only thing is, which to choose?
Unread 13-05-2011, 10:10
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
Most roller claws this year use rollers in the 1"-2" range. The smallest an Andy Mark plaction wheel comes in is 4 inches.
2010 GKC Finalists
2010 OKC Champions
2012 CO Finalists
Unread 16-05-2011, 02:37
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
2984 used the tall slim lego wheels. Worked well and was very lightweight.
Copied them off 100 in 2007.
Unread 16-05-2011, 13:04
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
-Brando
Fourth, just buy extra because they have serious wear potential.
