Go to Post But plywood is so awesome on robots...... But I guess shiny usually always wins out huh? - Jon K. [more]
Unread 13-05-2011, 05:36
Chris is me's Avatar
AKA: Pinecone
Jaguars + Vex Microcontroller?
So we at Shaker Robotics are pretty cheap. We want to wire up a drive base using a Vex controller to drive PWM signals since it's much cheaper than another CRIO + DSC. However, all of our Victors are on our competition robot. Since we have tons of Gray Jaguars lying around, and since we're never going to use them on a competition robot, we want to use those instead of Victors on the Vex-driven drive base. Is there any reason this wouldn't work?
My knowledge of electronics is very limited, but as far as I know, PWM is PWM so I don't see why it wouldn't work.
Unread 13-05-2011, 06:27
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Jaguars + Vex Microcontroller?
I believe that we do this on our Relay for Life robot. I can check when I get to the school today.
Unread 13-05-2011, 06:56
Flywheel Police
That is exactly what we did, and it works perfectly fine. We have 2 grey jaguars running through PWM.
Unread 13-05-2011, 07:31
Gdeaver Gdeaver is offline
FRC #1640
We have done that. However the jags default code uses a wider pulse than what the vex controller outputs so you will not get full speed. They could be calibrated to give full speed.
Unread 13-05-2011, 07:47
AKA: Pinecone
Is it "close enough" to full speed or dramatically less? How would we go about calibrating a Jaguar to work well with Vex?
Unread 13-05-2011, 08:01
See the calibration procedure on Page 13 of the MDL-BDC24 datasheet (attached) or Page 13&14 of the GSG (attached).
Name:	Jag calibration.png
ID:	10695  Click image for larger version
Unread 13-05-2011, 08:07
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
See the calibration procedure on Page 13 of the MDL-BDC24 datasheet.
Something tells me he didn't have to look that up.
Hi!
Unread 13-05-2011, 09:31
Based on PWM pulse widths, it should be about 60%, but I've never tested it.
Unread 13-05-2011, 10:30
Foster Foster is online now
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
From actual testing with a Jag and a CIM motor it's about 50%. The recalibration procedure is easy to do. When you are done MARK THE JAG THAT IT'S BEEN CHANGED. Otherwise you will have some unhappy FRC / CRIO programmers and electrical team members.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 13-05-2011, 14:03
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
it works because we tried it on our 2008 robot, fully operational! its great for a practice robot
