Go to Post The unlived life is not worth examining; the unexamined life is not worth living. - Sage-Theory6 [more]
Unread 10-05-2011, 23:03
Andrew Lawrence
Posts: n/a
FLL offseason task?
The FLL team that 256 mentors (Willow Glen Middle School) is having a team challenge. The challenge will pit half the team against the other half of the team to compete in a fully autonomous, FRC-like match. The 2 groups can only use parts found in the standard NXT 2.0 Kit of Parts, and items such as string, tape, and other household items. So, we've gotten the rules set up, but the only problem is we have no challenge for the robots to complete. So, that's where you at CD come in! Does anybody have any good ideas for challenges? We also have a limited amount of lego parts for game pieces, so common household items are preferred for game pieces.
Thanks!
Unread 10-05-2011, 23:17
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: FLL offseason task?
mini lunacy. play with ping piing balls. each team has to use wheels with no rubber on them, make the field roughly proportional. i could see a lego lunacy robot that would be pretty slick. 2 motors on drive, another one on belts, or teams can shovel.
Unread 11-05-2011, 09:35
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Robot sumo. It looks simple, but the autonomous behavior can get pretty complex. You also have to think about details such as how to get the best speed and traction you can with a limited set of parts.
Google around for videos and rules.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 11-05-2011, 10:03
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Put a barrier across the center of your normal field table. Use the duplo balls like the one from body forward, or ping pong, Start with an equal number on each side of the barrier. 3 minute challenge is to have the fewest balls on your side of the table at the end.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 11-05-2011, 11:19
MarkoRamius1086's Avatar
MarkoRamius1086 MarkoRamius1086 is offline
Robot Inspector
AKA: "Petrie"
FRC #1086 (Blue Cheese)
MarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to beholdMarkoRamius1086 is a splendid one to behold
I really like that last one! I would make sure that the barrier dividing the FLL table is white or some other color than the standard black wall. Is there a size limit to the robot in this challenge? I know FLL robots are currently restricted to 12x12x12 inches (the Base volume).
HEROES DIE, BUT LEGENDS LIVE FOREVER!
Unread 11-05-2011, 20:30
Andrew Lawrence
Posts: n/a
Any height, and width, as long as the parts used are in the available kit, and the included string, rubber bands, etc.
Unread 12-05-2011, 21:52
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
I second this one. We started sumo with our FLL teams after the Body Forward season was over; the kids are having a blast. As are our high school FRC mentors (and a certain adult mentor, who shall remain nameless) .
The build isn't necessarily simple; you can use some pretty complex features. There's a LOT you can do with programming. Unfortunately, multi-tasking with NXT-G isn't pleasant, but it can be done.
Mentor http://www.teamtitanium.org/
Unread 13-05-2011, 00:40
FRC #2170
I'd qualify the sumo choice for the case of an older FLL team. The presence of FRC-aged mentoring will help immensely with the building and programming nuances involved in robo-sumo competition. The game requires a special playing field/board too.
The most satisfying part about your post is that your FRC team apparently understands the value of a "farm team" approach to sustainability. They seem to know whence cometh replacement FRC team members.
Unread 13-05-2011, 02:18
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
Find one of the internet's NXT Bluetooth Remotes, run off of PS2 controllers, and recruit future drivers. I was the TA for a summer robotics class and I had the students play a teleop game with the balls that come in the NXT kits; they had a blast.
The game itself was fairly simple and made using nothing but cardboard boxes, an FLL board, and some textbooks. Arrange the balls in the center of the field. Place the textbooks the short way across the field, about a foot from the end, and use the cardboard to make a ramp from partway between the books and the middle of the field up to the books themselves. In the exact center of the field, use painter's tape to make a small box. The goal is to retrieve the balls from the middle and dump them over the edge of the textbooks into a goal zone. At the end, any robot in the center box receives bonus points, creating pseudo sumobot. You can add an autonomous period if you like.
It's fun, it recruits drivers, and it has the added bonus of teaching the kids how to build the FLL cage, which is among the most commonly used of all FLL manipulators.
Unread 13-05-2011, 12:12
Eagleeyedan's Avatar
Eagleeyedan Eagleeyedan is offline
C.O.R.E.; We build on each other
AKA: Daniel C.
FRC #2062 (C.O.R.E. 2062)
Eagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the rough
We just have our kids re-do themes they haven't done before so since our FLL team was all rookie members this year, we are having them do Climate Connections but I like the mini lunacy idea!
Former Driver and Safety Captain of team C.O.R.E. 2062 (Community of Robotic Engineers)
2015: Wisconsin Regional- Champions, Industrial Safety Award
Midwest Regional - Champions, Industrial Safety Award, Industrial Controls Award
2014: Midwest Regional - Judges Award
2013: Lake Superior Regional - Champions
2012: World Championship - Industrial Safety Award, World Finalist for the Autodesk Award
2011: Wisconsin Regional - Website Award 10,000 Lakes Regional - Innovation in Control, Safety Award
2010: World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
10,000 Lakes Regional - Regional Champs, Entrepreneurship Award
Wisconsin Regional - Entrepreneurship Award, Industrial Safety Award
2009: WI Regional- Quality Award, Industrial Safety Award
10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008: World Championship - Industrial Safety Award,
Wisconsin Regional - Champions, Industrial Safety Award
Unread 13-05-2011, 15:41
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
http://www.robofest.net/
We did the 2009 competition in robofest with our FLL team, nice break, end of the year event, simple games, no project.
You could look up a few years, all the games are played with household items, on a banquet table. (hint, start with the table legs folded on the floor, $300 nxt's survive 2" drops better than 30" drops.)
The sooner we get behind schedule, the more time we have to catch up.
Last edited by tr6scott : 13-05-2011 at 15:55. Reason: Lost a year there, it was 2009
