Go to Post One of the big things in FIRST is going global. - JosephC [more]
Unread 13-05-2011, 17:28
AB Steven AB Steven is offline
FRC #0245
AB Steven is an unknown quantity at this point
Downloading Code with Windows 7
Hi, our team is trying to switch over to C++ and we can't get code to download. Will WindRiver 3.0's download button work with Windows 7 64 bit? We were trying to use the 2010 version before this season started, and we had the same problem. WindRiver tells us the code has downloaded but our driver station says there is no code. Does anyone know what is wrong/if it doesn't work with 7?
Unread 13-05-2011, 17:50
Re: Downloading Code with Windows 7
It's not supported on Windows 7 64 bit. http://frcdirector.blogspot.com/2010...0000-feet.html It is supported on Windows 7 32 bit.
If you search chiefdelphi, you'll find a few threads about it with workarounds that don't always work, but might work for you.
Unread 13-05-2011, 19:19
FRC #0245
I tried searching on the forums, and on Google and couldn't find anything. Do you have any links to the threads?
Unread 13-05-2011, 20:30
http://www.chiefdelphi.com/forums/sh...ad.php?t=88074
Unread 13-05-2011, 20:44
Here's a few others
http://www.chiefdelphi.com/forums/sh...ad.php?t=89086
http://www.chiefdelphi.com/forums/sh...ad.php?t=89994
http://www.chiefdelphi.com/forums/sh...ad.php?t=91375
http://www.chiefdelphi.com/forums/sh...ad.php?t=91292
http://www.chiefdelphi.com/forums/sh...ad.php?t=93939
Unread 13-05-2011, 21:05
FRC #0245
Thanks for all the links, but unfortunately they didn't help. It seems like they're all just saying go to 32 bit. Does the download command in wind river just copy the .out file you set in preferences to the crio? Maybe ftping and copying it myself would work.
Unread 13-05-2011, 22:21
If you're able to produce the .out, then yes it only needs to be transferred to the cRIO using ftp.
Unread 14-05-2011, 14:46
FRC #0245
Ok cool, not as nice as using WindRiver to deploy since I probably wont be able to debug from my laptop, but better than flash driving to someone else's laptop whenever I need to deploy. So all that needs to be on the cRIO is the .out file?
Unread 21-05-2011, 22:28
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Greetings!
My team runs C++ on 64-bit Windows 7 and also found this problem with downloads. The solution for us was to use filezilla to transfer the .out after it had been compiled. The file needs to be renamed FRC_UserProgram.out. That worked like a champ.
Good luck,
Mike
