Go to Post FIRST is similar to real life in that nothing is perfect and you have to deal with the circumstances as they arise and make the best of it! - Sean_330 [more]
Unread 14-05-2011, 19:29
dudefise dudefise is offline
FRC #2637 (Panthers)
dudefise is an unknown quantity at this point
Mecanum Wheels
Does anyone have instructions on making mecanum wheels? Or a source of cheap mecanum wheels? The ones from Andymark seem really expensive...
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
Unread 14-05-2011, 19:37
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: Mecanum Wheels
i cadded a set of mechanums that i calculated would cost less than 50 dollars a piece, but they require a 5 axis mill, and some casting work, i could dig out the cad files if you like. if you want to know all the math involved in making them, here we go:
the most important thing to do is to understand that the profile of the roller is a partial ellipse, where the short dimension is the diameter of the wheel, and the long dimension is the diameter of the wheel divided by the sine of whatever angle the rollers are at (usually 45) after that bit of math there is really not much to designing fully custom mechanums.
http://chiefdelphi.com/media/photos/35738
here are the renders of the mechanum wheels that i did, the blue one should cost around 50 dollars, (depending on what casting compound is used for the rollers.
Unread 14-05-2011, 19:42
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: Mecanum Wheels
No sorry, but i'm curious why are you looking at mecanums?
If you want to do an off-season project mecanum might not be the best system for you and your team.
Unread 14-05-2011, 19:43
Re: Mecanum Wheels
There aren't exactly a lot of sources of mecanum wheels in the FRC size range. AndyMark is the biggest (and to some extent, the only) one.
You may want to get in touch with 357 (or, the Behind the Design books from the 2006 and 2007 FRC seasons); they've got casting their own down to a fine art.
Or, if you can find someone who can build them directly with a direct manufacturing machine, that might do it. Just watch out for FRC cost rules--the material can get pretty expensive.
Matt, offseason is the best time to do mecanum. Not during the season. 330 spent 2 offseasons prototyping a set before giving them a chance to make a competition robot in the build season.
Unread 14-05-2011, 19:51
Re: Mecanum Wheels
It's for a shifting drivetrain project. It will have mecanum for speed and agility and tank for brute strength (with traction wheels) and the ability to switch between the two.
Unread 14-05-2011, 19:55
pfreivald's Avatar
AKA: Patrick Freivald
Re: Mecanum Wheels
357 has a pretty impressive setup. Michael Crane is probably a good contact person from that team to ask about how they make their own.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 14-05-2011, 20:03
MattC9's Avatar
Re: Mecanum Wheels
Nice!!! that sounds sweet!
well i did some searching and the robot shop has some for about 85 for a 4 pack (for the alum. hubs and 75 for plastic hubs) but the O.D. is 2.125. You might be able to do some prototyping with them using vex parts then decide if you want to drop 400 for the AM ones. Our team has done a pure mecanum drive for the last 2 years (we will not go back to it, but the AM heavy duty ones work really well).
Heres the link for the robot shop ones
PS if i did come off as negative, i just don't like a pure mecanum drive.
Unread 14-05-2011, 20:22
AKA: Isaak
Team Role: CAD
Re: Mecanum Wheels
http://www.thingiverse.com/thing:2473
http://hackaday.com/2010/04/28/print...um%C2%A0wheel/
if you have a 3d printer you could always scale a set of these.
Unread 14-05-2011, 20:32
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Mecanum Wheels
I've seen 357's casting method up close and it's pretty awesome, though I don't see most teams being able to do it. 357's wheel body is also it's own work of art - which again is pretty difficult to make, imo.
I 3D printed a set of Mecanum wheels back in '07/'08 and there's no way they'd stand up to the abuse of an FRC robot.
Not really sure why the OP doesn't want to use AM Mecanums, at $222 a set they seem like a steal.
-Dustin Benedict
Unread 14-05-2011, 20:33
pfreivald's Avatar
Re: Mecanum Wheels
There is that. I'm pretty happy with the AM HD Mecanum wheels.
Team 1551
I write books, too!
Unread 14-05-2011, 20:38
Re: Mecanum Wheels
I was assuming they were expensive for mecanum wheels; they seem expensive for the materials that go into it. But if they're the best option available, I'll take it.
Also I don't think the printed wheels would survive if we were to use them.
Unread 14-05-2011, 20:46
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: Mecanum Wheels
I have made a set of mecanum wheels that were not for FIRST robotics but used in a high capacity application and the machining of them does not take too much work but more a good deal of time. I can speak more on the machining of the hubs than how to make the rollers because I used a neoprene rubber for the rollers with a nylon core and the neoprene was just too soft. As well as there are much better ways to make the rollers than how I did (CNC Lathe).
As for the machining of the hub I did it in a 3 step process where I started with a 6x6x1in block of aluminium and the first operation I cut out the profile of the wheel hub, the center bore for a FR8 bearing and a 6 hole pattern at 1.875". Then using the 6 hole pattern I used it to mount it to a fixture which stood the hub up vertically and I then used that to cut the fins and drill a hole that I would a #10-32 set screw in. I did 6 fins so that they would line up with the hole pattern and it just made life simpler. I rotated the part to cut each fin one at a time. Then I had another fixture which held the part at a 45 so that I could fillet the corners of the fins and drill a 1/4" hole for the axle of the rollers. The part was also rotated on this fixture for each fin.
I have also uploaded some pictures of the manufacturing process here:
https://picasaweb.google.com/j3ffr3y...eat=directlink
Hope that helps.
Unread 14-05-2011, 20:57
Re: Mecanum Wheels
nice photo.
Did you use ball, roller, or journal bearings for the rollers? Can't tell from the photo.
Unread 14-05-2011, 21:00
Jeff 801's Avatar
Re: Mecanum Wheels
nice photo.
The bearing surface is nylon on a 1/4-20 bolt (the nylon rolls on the shank of the bolt and not the threads) And between the neoprene roller and the fin there is a Hard Fiber washer from mcmaster
Unread 14-05-2011, 21:10
Re: Mecanum Wheels
When the roller is axially loaded toward the fin, is the neoprene rubbing against the Hard Fiber washer ?
