Re: Minibot Ramp
Re: Minibot Ramp
did anyone think of having a "U" so that the mini-bot goes down a pole, then that energy is converted into upward motion, there would be no launch, so it should be legal.
Re: Minibot Ramp
Re: Minibot Ramp
If the deployment mechanism is a ramp, and the minibot generates it's own kinetic energy, then it is all legal. The ramp cannot be in contact with the minibot as it crosses the 18 inch line, so it has to be short.
With no friction and constant thrust (torque with no slip) then I believe the optimal to be a cycloid. You really want the math? If you have already reached top speed, then I believe you would just want an arc. |
Re: Minibot Ramp
Also, I clearly remember these minibots with these ramp deployment devices being used at the Championship event so I'm almost 100% sure they're legal. The rule you are looking at is <G19> and it states: MINIBOTS must remain completely autonomous and move up the POST solely through electric energy provided after the start of DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry). <G19> means that HOSTBOTS are not allowed to launch the MINIBOT up the pole at the TARGET, or otherwise contribute to the vertical movement of the MINIBOT. Energy for vertical movement may not be stored in the MINIBOT before DEPLOYMENT (except that which is contained within the battery and excluding incidental kinetic energy stored in the motors or wheels, but NOT, for example, in a flywheel). While hostbots may not "launch" minibots up the pole, I believe that these teams basically start the minibot's motors while it is on the ramp so it will use the ramp as a track to gain speed before it gets to the pole (under its own power); therefore, there is no violation of <G19> |
Re: Minibot Ramp
You'll find an interesting discussion of ramps (and their legality) here:
http://www.chiefdelphi.com/forums/sh...68#post1054268 |
#7
Re: Minibot Ramp
I'm gonna make an attempt to divert this discussion back to what the OP was asking about.
We too have been thinking of making this setup on our robot just to have fully optimized the task even if it wasn't at the competition. I know I would love to get some input from teams like 233, 190, 254, 1114, 2056, 217, 71, 973, 368, 1986, 177, and any and all others that I couldn't think of on Duke461's questions and any other details on how they managed to pull off the awesomeness that is the ramp deployment. |
#8
Re: Minibot Ramp
I'd like to keep this focused on my original question, not the legality. There are a multitude of other threads to discuss that and that was not an intended part of this discussion. Quote:
Im not the most studied on my physics and whatnot yet, but on wikipedia it says the Cycloid is for "the curve of fastest descent under gravity". Does this method still apply for upward descent? Thanks. Other suggestions and statements regarding minibot ramps, and not their legality, are greatly appreciated. Thanks, -Duke |
#9
Re: Minibot Ramp
The cycloid curve solves the classic (~300 year old) brachistochrone problem. The important feature of a such a "curve of fastest descent" it that it converts all of the falling particle's energy from vertical to horizontal motion in the least time. Applying the same criterion in reverse, to convert a minibot's energy from horizontal to (upward) vertical motion, will yeild the same curve.
#10
Re: Minibot Ramp
Re: Minibot Ramp
Re: Minibot Ramp
Re: Minibot Ramp
If you like this kind of problem, try your university's course in Calculus of Variations -- generally a graduate-school topic for engineers, or an advanced class for students of applied math. |
#14
Re: Minibot Ramp
For high-school students interested in math and/or physics, the attachment shows how to use high-school-level calculus to figure out the travel time from point A to point B for a particle sliding down an arbitrary frictionless curve. You can replace f(x) with a straight line or a parabola or a cycloid or whatever and see the difference. Last edited by Ether : 16-05-2011 at 20:57. |
#15
Re: Minibot Ramp
Okay. Step 0 should be to actually define the math problem we are trying to solve. I believe we can put that within the reach of high school math. Here goes...
In optimization we construct a "cost function" and try to minimize it... nobody ever wants to maximize the cost they pay. You can maximize its negative, would that be a "profit function?"Anyways, the cost function we have here is the total time from breaking the plane on the tower to the top of the pole. We can divide the motion into three parts: (1) flat extension to the ramp (start with a non zero initial velocity when breaking the plane) (2) transition to vertical (the ramp). Beginning with the speed and position where the last segment left off. We further assume the ramp must be tangent to the horizontal at the robot side and tangent to the pole at the pole. This is known as a "constraint" and we can consider any solution as long as this is true. We have another constraint in the form of <g22> so assuming a 6" mini-bot, the ramp cannot extend beyond 12" maximum. (3) vertical assent (the pole). Beginning with speed and position where the last problem segment left off, climb what is left of the pole. Then recording the final time is the cost function. We must be careful about optimizing a subset of the problem, such as the transition to vertical (the ramp), because it could lead us away from the best total solution. One can imagine a solution which starts on the ramp much earlier and takes longer to traverse (the ramp), but has a shorter total time. One can also imagine a solution which leaves the ramp at a later time, but with a higher speed and passes all other bots on the way up. Given these three stages of motion, your next task is to come up with "good" models of the mini-bot behavior in each. Example 1: Let us assume that the mini-bot has reached terminal speed when it crosses the plane and that the terminal speed can be approximated as the same constant value when moving horizontally and vertically. This is actually a good model if we've got a really large a gear ratio on our mini-bot. In this case, the time to the top is the total distance divided by the constant mini bot speed. The minimum time is therefore the minimum distance, a straight line!! But subject to our constraints, you end up with a straight line ramp from the edge of the mini-bot tower to 12" up the pole with infinitely small fillets (rounded bits) on the ends to make the motion "smooth." Clearly our notion of smooth was abused by this solution, so we need a better model... some kind of penalty for less smooth motions. If you were to restrict the radius of curvature not to go below 2x the "wheelbase" of your mini-bot, then the solution is a smaller straight portion with fillets of 2x the wheel base. We were able to solve this in our heads and we actually solved this like a real "calculus of variations" problem but only because the answer was obvious. Example 2: If your mini-bot cannot be approximated as a constant speed machine, then your first model would likely involve a solution for acceleration as a function of speed and incline angle (a = F/m where F includes gravity and the speed dependent thrust of the motor). 302 has a mini-bot spreadsheet which numerically integrates (calculus) such expressions for mini-bot pole climbing and you don't need to know calculus to understand it. Anyways, if we set one of those up, then we have the cost function. This type of cost function is not generally amenable to working out by hand via the calculus of variations. However, you can greatly simplify things for the computer, allowing it to finish computing in your lifetime, by using those methods. Instead I'll describe the "brute force" optimization approach. Once you have the cost function, you can change the values of the inputs (the ramp shape) and see what the final time is. if there were only two inputs (x and y), then cost (time) gives you a third value (z) which is like a topological height map of mountains and valleys. Extending this analogy, a numerical procedure "walks" down the hills and stops at the bottom of the nearest valley. Different starting points potentially land you in different valleys... so you need to "explore" a bit. The number of variables describing our ramp will be more than 2 (we'll use a many intermediate points), so it's difficult to visualize it as any kind of "terrain", but numerical procedures don't care and figure out which "direction" to walk (sometimes randomly!) and eventually find their way to a bottom. The best bottom you find is the solution you would use. That's how you would solve the problem. Do you want to setup a spreadsheet to define the cost function? |
