Minibot Ramp
I've been reading through all the minibot threads on Chief Delphi that include ramps in the deployment design, and i have found very little in-depth description of their designs. I'm essentially wanting to know, what it is the best angle/diameter for the ramp to maximize the speed/minimize the time of the minibot reaching the top? Im assuming weight, magnets, friction, etc. would factor in. If someone could post the math to figure this out, or what they did to maximize efficiency would be greatly appreciated.
Thanks from team 461, -Duke |
Re: Minibot Ramp
Re: Minibot Ramp
Ramps or the deployment methods are only allowed to move the minibot into a legal "deployed" position. From that deployed position the minibot has to climb without carrying any momentum or other assistance across the interface between the deployment process and the climbing process. So (if I am right) I think your question is irrelevant? Blake |
Re: Minibot Ramp
Re: Minibot Ramp
did anyone think of having a "U" so that the mini-bot goes down a pole, then that energy is converted into upward motion, there would be no launch, so it should be legal.
Re: Minibot Ramp
Re: Minibot Ramp
If the deployment mechanism is a ramp, and the minibot generates it's own kinetic energy, then it is all legal. The ramp cannot be in contact with the minibot as it crosses the 18 inch line, so it has to be short.
With no friction and constant thrust (torque with no slip) then I believe the optimal to be a cycloid. You really want the math? If you have already reached top speed, then I believe you would just want an arc. |
#8
Re: Minibot Ramp
Also, I clearly remember these minibots with these ramp deployment devices being used at the Championship event so I'm almost 100% sure they're legal. The rule you are looking at is <G19> and it states: MINIBOTS must remain completely autonomous and move up the POST solely through electric energy provided after the start of DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry). <G19> means that HOSTBOTS are not allowed to launch the MINIBOT up the pole at the TARGET, or otherwise contribute to the vertical movement of the MINIBOT. Energy for vertical movement may not be stored in the MINIBOT before DEPLOYMENT (except that which is contained within the battery and excluding incidental kinetic energy stored in the motors or wheels, but NOT, for example, in a flywheel). While hostbots may not "launch" minibots up the pole, I believe that these teams basically start the minibot's motors while it is on the ramp so it will use the ramp as a track to gain speed before it gets to the pole (under its own power); therefore, there is no violation of <G19> |
#9
Re: Minibot Ramp
You'll find an interesting discussion of ramps (and their legality) here:
http://www.chiefdelphi.com/forums/sh...68#post1054268 |
#10
Re: Minibot Ramp
I'm gonna make an attempt to divert this discussion back to what the OP was asking about.
We too have been thinking of making this setup on our robot just to have fully optimized the task even if it wasn't at the competition. I know I would love to get some input from teams like 233, 190, 254, 1114, 2056, 217, 71, 973, 368, 1986, 177, and any and all others that I couldn't think of on Duke461's questions and any other details on how they managed to pull off the awesomeness that is the ramp deployment. |
#11
Re: Minibot Ramp
I'd like to keep this focused on my original question, not the legality. There are a multitude of other threads to discuss that and that was not an intended part of this discussion. Quote:
Im not the most studied on my physics and whatnot yet, but on wikipedia it says the Cycloid is for "the curve of fastest descent under gravity". Does this method still apply for upward descent? Thanks. Other suggestions and statements regarding minibot ramps, and not their legality, are greatly appreciated. Thanks, -Duke |
#13
Re: Minibot Ramp
My opinion: Straight horizontal ramps are legal. All energy comes from the minibot.
Ramps that go down or "U shaped" ramps are not, as potential energy is gained. |
#14
Re: Minibot Ramp
we just used some good old fashion guesswork and intuition
#15
Re: Minibot Ramp
Yay for guessing ![]() |
