Go to Post If you look at where you have come from you can often tell where you are going. - Turtlecoach [more]
Unread 07-02-2010, 12:53
mark.amber mark.amber is offline
FRC #2039
mark.amber is an unknown quantity at this point
We have some things working with java, if you need help look here
I am creating this thread because we needed some help getting all the things working on the robot.
We are using the following computer systems for programming in JAVA:
  • Ubuntu 64 bit, running netbeans 6.8 successfully (Ubuntu 9.10)
  • Ubuntu 32 bit, running netbeans 6.8 successfully (Ubuntu 9.10)
  • Windows Vista, running netbeans 6.8 successfully
Classmate PC running:
  • Netbeans 6.7.1. we do not use netbeans on the classmate
  • Updated driver station with compass in bottom right.
  • Recieving feed of camera from cRIO.
  • Working comunication.
The cRIO:
  • Using Victors.
  • Connected to camera, seems to run the default circle detection code, follows circles with this code.
  • Connected to a WGA600N Gaming adapter, connected to our local network, all Computers listed can download to it.
  • Working Gyro for compensating for the orientation of the robot.
  • Working Servo for adjusting camera angle.
Code contains working sections for:
  • HolonomicDrive: setup so no matter what direction the robot is heading, it will respond to the joystick the same (using mecnum wheels)
  • Controls camera position on servo using a throttle on Attack3 Joystick.
  • Using iterativerobot class
  • Using multiple methods, so the code is segmented, and easier to debug
  • Debug output to Netbeans working.
Procedures we know
  • We know the procedure to download code to the cRIO from Netbeans (complicated).
  • We know how to flash the cRIO with the latest image.
  • We know how to setup the Axis camera, for use on the cRIO.
  • We know how to use the Vision Assistant 2009 to test out different filters.
  • We know how to install the latest updates for driver station (complicated).
Just respond to this thread if you want to know how to do one of these things, just quote it, and tell any relevant information.
Unread 08-02-2010, 14:43
sunit sunit is offline
FRC #1504
sunit is an unknown quantity at this point
Re: We have some things working with java, if you need help look here
We are looking for some sample code that displays images from the camera on the driver station display. The sample code talks about instantiating the class and then setting brightness level and resolution.
What do we do after the camera instance is created in code to display the picture?
- Sunit
Unread 08-02-2010, 14:55
AKA: Brad
#0190 ( Gompei and the Herd)
If you create a sample Java project - the CircleTrackerDemo it will track the target and display the output on the dashboard. You should be able to use that as a model to write your own programs to track the target and display images. When the camera is running it will automatically tries to connect to the dashboard program and send images.
Brad
Brad Miller
Robotics Resource Center
Unread 09-02-2010, 19:25
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Mind posting your code on the section about the servos? We couldn't ever get it to work beyond one single movement. (Ex:We can set the sensitivity to whatever we want, but it will only move once in any direction.)
Unread 14-02-2010, 10:36
FRC #2039
sorry for forgetting about this thread.
to get camera feed put this in the import section
import edu.wpi.first.wpilibj.camera.AxisCamera;
and this in robot init
AxisCamera.getInstance().writeResolution(AxisCamer a.ResolutionT.k320x240);AxisCamera.getInstance().w riteBrightness(0);
that will start getting the image from the camera, make sure that you have the camera configured properly by using the circle tracker demo
for the servo, you just use:
Servo servo = new Servo(slot, 10);
then to tell the servo where to go you use
servo.set(-1 to 1)
you could also say
servo.set((Joystick(1).getX())) now the servo will go up and down with the jostick
Unread 28-03-2011, 08:25
johncap100 johncap100 is offline
FTC #0658
johncap100 is an unknown quantity at this point
do you have a copy of this default code from last year that you might share, or do you know where i might get a copy from last year?
thanks
The cRIO:
  • Using Victors.
Procedures we know
Unread 28-03-2011, 22:40
Hello Java gurus.
Sorry if this is slightly off-topic, but I've got a Java question I've been unable to find an answer for.
Can anyone tell me: If you start several threads at the same priority, what scheduling policy is used to run them concurrently?
Someone said it was not time-based, but rather based on number of bytecodes executed. Is this correct, and can anyone link to a document where this is discussed? I'm referring to the 2011 FRC Java Framework implementation here specifically.
Thank you.
Unread 14-05-2011, 23:31
Ivan913's Avatar
Ivan913 Ivan913 is offline
FRC #3560
Ivan913 is an unknown quantity at this point
My team is trying to switch over to Java from C++ and we're having difficulties getting netbeans to find the wpilibj class files. I followed the "Getting Started with Java for FRC" pdf. Everything goes off without a hitch except until I try to instantiate any of the wpilibj classes, in which case it tells me it "cannot find symbol".
Unread 15-05-2011, 00:12
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
hello Ivan, the WPILibJ library is made available to NetBeans by installing the FRC NetBeans plugins found at http://firstforge.wpi.edu/sf/frs/do/...e_for_2011_frc. You can either download the files and install them manually, or link NetBeans to the site and allow it to check for updates on it's own(with an internet connection at least). To let it search automatically, point the NetBeans plugin manager to http://first.wpi.edu/FRC/java/netbea...te/updates.xml.
Let me know if you have any more questions. I can give you a step by step if you would like.
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 15-05-2011, 00:27
Ivan913's Avatar
FRC #3560
I already installed the plugins. I've actually done it multiple times. Twice using by linking netbeans to the update site, and once by downloading them manually. In each case all works fine. I can see the little frc logo on the menu and all that. I can open the javadocs and open the templates and everything. But every time I try to test out a SimpleRobot template, I try to instantiate something simple like a gyro or accelerometer and it can't seem to find it. Im running windows 7. Under the FRC Configuration tab in the options menu its using the standard WPILibJ location. The file path is C:/Users/Ivan/sunspotfrcsdk/lib/WPILibJ. Any clue what I'm doing wrong here?
Unread 15-05-2011, 12:24
Strants Strants is offline
AKA: Gavin Stewart
FRC #1977
Strants is an unknown quantity at this point
Are you importing the file? Assuming the SimpleRobot class itself doesn't cause you any problems (and from what you've said, that appears to be the case), I would say you just need to import the files. For example, to import a Gyro, you would put this code at the top of the file, under the package name:
import edu.wpi.first.wpilibj.Gyro;
This is the same as an include statement in C++. In Netbeans, you can also just press ctrl+i, and the editor will take care of the imports for you.
Unread 15-05-2011, 13:40
Fletch1373's Avatar
AKA: Fletch
So the SimpleRobot template with no modifications still gives you errors? If you are making modifications to the template, make sure you're importing the classes like Strants said. The plugins "should" make everything work. However, on my laptop I've always installed the Labview libraries and DriverStation/dashboard programs first, so it's possible that something in one of those is needed by netbeans....? (unlikely, but who knows)
Student:
Mentor:
Volunteer:
2016 Tour:
Unread 15-05-2011, 19:06
Ivan913's Avatar
FRC #3560
As embarrassed as I am to say it, you guys are right, it was the imports. Its working fine now. Big thanks .
Unread 16-05-2011, 00:10
Fletch1373's Avatar
AKA: Fletch
no problem, I'm glad to help
Student:
Mentor:
Volunteer:
2016 Tour:
Really need some help here... synth3tk General Forum 5 23-05-2008 17:29
Need some help with arm not working... neilcooper Programming 3 15-03-2008 06:16
can i have some help with quadratic equations CmptrGk Math and Science 9 13-12-2004 21:33
Have you ever had fish as a "pet"? If so look here please! Elgin Clock Chit-Chat 15 24-11-2004 19:11
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
