Go to Post to all of the people who are on robotics, I thank you for giving me the chance and happiness that i had never had before. robotics has been the happiest thing i have ever done in my life - gondorf [more]
Unread 16-05-2011, 21:44
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
pic: Team 610's 2011 robot design
Unread 16-05-2011, 21:45
Chris is me's Avatar
AKA: Pinecone
Re: pic: Team 610's 2011 robot design
I'm confused by the placement of the gas spring. Wouldn't the gas spring be pushing the arm into the ground, increasing the load?
Unread 16-05-2011, 21:50
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
if i remember correctly that is a pneumatic cylinder to aid in lifting.
Unread 16-05-2011, 22:41
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
can you post a link to the CAD File
Thanks
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 16-05-2011, 22:51
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Thanks
http://www.chiefdelphi.com/media/papers/2534
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 16-05-2011, 23:26
DMetalKong's Avatar
DMetalKong DMetalKong is offline
AKA: David K.
DMetalKong is a jewel in the roughDMetalKong is a jewel in the roughDMetalKong is a jewel in the rough
Send a message via AIM to DMetalKong
The gas spring probably pulls inwards rather than pushing outwards, in which case it would make sense because it will be tugging the lever-arm on the other side of the pivot down, making the manipulator rise.
Unread 17-05-2011, 08:26
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
If the electrical/pneumatics side of the team was as diligent about CAD, it would be a lot more clear.
There is pressurized air supplied to only one side of that pneumatic cylinder, such that it is constantly pulling downwards. We had that air supply regulated to about 40 PSI, and it perfectly counterbalanced the arm uniformly through its entire length of travel, on both sides of the robot.
Unfortunately, whenever we ran the arm downwards, the air in the cylinder would compress, and the regulator would bleed excess pressure. While this was desired for both safety and uniform counterbalancing reasons, it used up a lot of the air whenever we moved our arm downward.
We ended up replacing the setup with a few loops of surgical tubing.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 17-05-2011, 09:54
FRC #0610 (Coyotes)
The reason for using an air cylinder instead of a gas spring was because we wanted the arm to swing both ways to pick up on either side of the robot. Most gas springs push instead of pull, and putting one underneath the arm would have caused interference with the arm pivot, limiting the range to less than 180 degrees. Pulling from the back end of the arm allows the cylinder to swing underneath the pivot and then serve to balance the arm when it is facing the other direction.
I have since learned from an 1114 mentor that "pull" gas springs are readily available. Good to know.
