Go to Post I think Dave has been spending time on icanhascheezburger. Either that or the fumes from his rendering machines have affected the grammar control portion of his brain. - rsisk [more]
Unread 16-05-2011, 14:37
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Legality of Downwards-Sloping Ramps
Originally Posted by Jeffy View Post
The rulebook
<G19> MINIBOTS must remain completely autonomous and move up the POST solely through electric energy provided after the start of DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry). <G19> means that HOSTBOTS are not allowed to launch the MINIBOT up the pole at the TARGET, or otherwise contribute to the vertical movement of the MINIBOT. Energy for vertical movement may not be stored in the MINIBOT before DEPLOYMENT (except that which is contained within the battery and excluding incidental kinetic energy stored in the motors or wheels, but NOT, for example, in a flywheel).
I meant after the start of deployment, sorry for not clarifying that.
Last edited by PAR_WIG1350 : 16-05-2011 at 14:39. Reason: to remove foot from mouth
Unread 16-05-2011, 15:35
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
Oh boy look what we started. It was on my Facebook that the video of our downwards sloping ramp was posted.
Our minibot never "rolls" down the ramp. Any movement on the ramp is purely from the battery and minibot motors.
Chris said it best, the minibot stays below the deploy line the entire time and our "exit" point off the ramp is higher then the starting point so any energy gained by the ramp is lost.
I mean if we're going to lawyer this then the refs should have used a bubble level to make sure all deployment mechanisms fired out level or downwards. Any increase in degrees would mean the deployment mechanism is "pushing" the minibot up when it contacts the pole and arguably providing vertical movement to the minibot.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 16-05-2011, 17:41
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Our team was also slightly confused by the wording, and noticed several teams on our field (Arch) at St. Louis with downward-sloping ramps. We asked the lead inspector of the field and he very specifically told us that they ARE legal as long as all the other language is met (below the deployment line while in the tower cylinder, etc).
Unread 16-05-2011, 18:34
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'll throw in against downward sloping ramps. Actually most ramps if you're strict about the rules. I'll admit up front that this is all going to be based off an extreme examples that have never and would never make it to the floor. The first example being a ramp that starts several feet above the top of the pole, and a deployment mechanism that's smart enough to trigger far enough in advance that the falling minibot crosses the cylinder just after the endgame starts.
That said, I think it's patently obvious that said minibot gains an advantage from dropping from such a height. That can be pretty readily demonstrated by the fact that you could use this ramp to create a (highly dangerous) ball bearing minibot that wouldn't be fundamentally different from a spring catapulted minibot. So I'm failing to appreciate how slapping two motors and a battery on to would appreciably change the situation. You're storing potential/kinetic energy in the minibot that it pretty directly transfers into vertical motion. It seems patently obvious to me that said minibot has gained a significant advantage over minibots that run a straight track out to the pole.
If you admit that the extreme example creates an advantage, then you're down to deciding how much of an advantage is too much. Which I'm fine with, but we should be honest that that's what we're discussing.
Similarly, I think the argument could be made that nearly ALL ramp systems are illegal by a (very) strict reading of the rules. G19 etc. state that the minibot must move up the pole with electric energy provided by the battery AFTER deployment. Deployment starts when the minibot crosses the cylinder. Ergo, any ramp system where the minibot starts a significant distance away from the cylinder is putting significant energy into the minibot system before deployment starts. It's kinetic energy stored in the inertia of the battery and frame, but it's stored energy all the same, and it would still provide an advantage.
You're again down to the question of what degree of advantage is acceptable. Which again is fine, but we should admit that.
Don't believe me? Grab your current interpretation of the deployment rules and reason along with me. Let's assume that the no-load speed of a legal minibot is 30 fps, versus a climbing speed of 15 fps. The following systems all have deployment timing such that the minibot crosses the cylinder after the endgame starts. Which, then, is illegal? Which is going to be the fastest?
1. A ramp system where the minibot starts just outside the cylinder at a dead stop.
2. The above sloped ramp system, where a minibot is dropped from a height sufficient to achieve 30 fps as it crosses the cylinder.
3. A novel flat ramp that is long enough that the minibot reaches 30 fps before crossing the cylinder.
4. An even more novel spring-loaded system that shoves the minibot up to a speed of 30 fps, releasing it just before it crosses the cylinder.
Timing and construction issues aside, I think system 1 loses to systems 2-4. But the interesting question is which of 2-4 seems illegal to you by your current reading of the rules. A really strict reading should deem all three illegal. If you think any of 2-4 are legal, ask yourself what real difference there is between them, as regards energy stored before deployment. On the plus side, it'd make rulings a lot easier, since you'd just be judge the speed of the minibot before deployment started.
Like I said, for me it all comes down to just how picky you want to be and want what degree of advantage you're willing to tolerate with the minibot rules. My level is set somewhere around all net energy coming from the battery, and the equivalent energy of a 3 foot long ramp. Mostly for practical reasons, since this would pass most ramp systems out there.
Unread 16-05-2011, 20:23
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Originally Posted by Kevin Sevcik View Post
... The first example being a ramp that starts several feet above the top of the pole, and a deployment mechanism that's smart enough to trigger far enough in advance that the falling minibot crosses the cylinder just after the endgame starts.
This is clearly illegal since after deployment not all of the energy came from the batteries - some of the energy came from the potential energy of having the minibot well above the deployment line.
If the minibot starts below the exit point of the ramp, then ZERO potential energy is used in the speed of the minibot at the end of deployment - even if the minibot travels all the way down to the floor before starting upward. Thus ALL energy comes from the batteries, which is 100% legal.
I agree with you here. Our ramp was constructed so our minibot starts on the edge of the cylinder (at least as close as can be repeatable). Starting the minibot a long distance from the the cylinder does provide an advantage as kinetic energy is stored before deployment begins.
Unread 16-05-2011, 20:47
Excellent post Kevin. Reps to you.
Unread 16-05-2011, 20:55
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
I guess as long as the minibot's starting position on the slope is lower than the end of the ramp on the deployment end, there isn't a net gain in energy, so it skirts around the rules.
It seems like the slope just gives the motors a break, they aren't exactly the best so it's a good idea to have them run as little resistance as possible before running up the ramp and pole.
I'd call it legal, but there's a lot of illegal things I'd try to call legal too
Unread 16-05-2011, 22:40
The Zevling's Avatar
The Zevling The Zevling is offline
Modern Major General
AKA: Jonathan Zev
FRC #0599 (Robodox)
Team Role: Scout
The Zevling is an unknown quantity at this point
One thing that I haven't seen mentioned is that there are two fundamental parts to a ramp: the downward sloping part that gets the minibot to the pole, and the upward sloping part that transforms the horizontal movement into vertical movement. I think they have been regarded as the same, but they should be regarded separately.
The downward sloping part should be considered legal, I think. Energy-wise, it's no different from storing the energy in a spring, or however else you're getting the minibot to the pole. A downward sloping ramp with a horizontal end seems perfectly legal to me.
The upward sloping part is the part that transforms any horizontal momentum into vertical momentum, and this is the part that I think is illegal. This is the piece that separates "Energy for vertical movement" which is forbidden in G19 from energy for horizontal movement, which is necessary to get the minibot to the pole.
I hope there's no flaw in my logic.
"Never imagine yourself not to be otherwise than what it might appear to others that what you were or might have been was not otherwise than what you had been would've appeared to them to be otherwise." - Alice in Wonderland
"Outside a dog, a book is man's best friend. Inside a dog, it's too dark to read." - Groucho Marx
"A man should live forever, or die trying." - Callahan's Crosstime Saloon
"[a] good bookshop is just a genteel blackhole that knows how to read." - Terry Pratchet
Unread 16-05-2011, 23:06
EricH EricH is online now
Nope, not quite.
Minibots are to use only the power in the battery, delivered through the motors. Springs (for traveling along the pole) would be considered illegal, for example--though certain types of springy material could be used for latches. So the downward portion would be illegal--gravitational potential energy is not listed as a legal minibot upwards power source (though it's the primary method for getting down).
With respect to the second part of your argument (upward ramps), there are actually 2 holes. The first is that ramps were considered legal at multiple events. Translation: either multiple inspection and ref crews really screwed up, or there's a legal way to do it.
The second is this: Power for vertical motion only comes from that battery, through those motors. The fact that it starts out horizontal does nothing to the motors providing all of the vertical motion. Somehow, that horizontal motion gets converted to vertical--in this case, by a stationary part of the hostbot that the minibot runs on.
In other words, it's precisely because the minibot is supplying all of the energy that the upward ramps are legal, and because it is not supplying all of the energy that the downward ramps are illegal.
Unread 17-05-2011, 07:44
Kevin,
We should keep in mind in your examples, practical implementations for weight and size which plays heavily on the actual advantage gained. Also it should be noted that the GDC did allow motors to be running throughout the match if a team wanted to use that approach. (Q&A 2/1/2011)
Unread 17-05-2011, 09:55
Kevin,
He was using hyperbole in those examples to make a point. He clearly stated that:
Kevin addressed the above point in his post:
Rule <G19> allows the minibot to store up kinetic energy in its spinning motors and wheels prior to start of deployment. That is a separate question from using those running motors to store up kinetic energy in the body of the minibot prior to start of deployment; a point which GDC did not clarify when asked, and which is at the heart of much of this discussion.
Unread 17-05-2011, 11:45
You all know that the season is over and that there are other more deserving expired horses to beat, right?
Unread 17-05-2011, 12:04
Like what, for example? :-)
Unread 17-05-2011, 12:08
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
I think one point to be made is that even if there is a positive change in net gravitational potential energy, any decrease that is converted to vertical kinetic energy is still illegal.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 17-05-2011, 12:57
I'm not sure what you mean - could you please explain that.
