Go to Post If only CD had a "like" button. - BrendanB [more]
Unread 17-05-2011, 09:35
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: Better Battaries for Driver Pratice
I'm not trying to put words into Chris Picone's post, but here's what I think he means. Suppose you got a 12v marine deep discharge battery and hitched up an Anderson connector to its terminals. It might then power your robot for a significantly longer time than the regulation batteries. However, the increased size and weight of that battery would significantly change the driving characteristics of your robot by traction, turning momentum, geometry of gripper arm's motion due to its size and alternate placement, etc.
The consensus seems to be invest in more of the same batteries and practice with them. You'll also get practice changing the batteries on the robot so you'll realize how important easy access is to the power source. To this I'll add: look around CD and other places for ideas about how to make a combination battery cart and charging station. Ride herd on your energy sources. It's also interesting to note that many teams have named their batteries for easier and more effective handling. It's much better to say "I'm going to use Delta now." than to wonder if an anonymous battery has a proper charge.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Last edited by Bill_B : 17-05-2011 at 09:38. Reason: Chris Mormile and I were posting at the same time
