Go to Post We design for being on a dysfunctional alliance: all the time. - boomergeek [more]
Unread 17-05-2011, 00:38
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Question Quick Motor Shaft Question
Hello,
I've recently been wondering how you'd remove a motor which was epoxied to, say, an aluminium roller. For example, an RS550 to a simple, aluminium roller, held in via epoxy. Will the process damage the motor or shaft in any way?
It takes a while for new motors to reach Australia.
Thanks in advance.
Unread 17-05-2011, 00:46
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Re: Quick Motor Shaft Question
If you don't mind my asking, how on earth did it end up epoxied anyhow?
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 17-05-2011, 00:55
It depends on the glass transition temperature of the particular epoxy which was used.
If you can heat the epoxy above its glass transition temperature without exceeding the temperature which would damage the motor that would allow you to separate the parts.
Once separated, you could use xylene or acetone to soften and remove the epoxy. Use chemical gloves and adequate ventilation.
Unread 17-05-2011, 00:56
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Well someone Who would think about this might want to look into acetone. *disclaimer* I'm suggesting looking into it not going ahead and doing it I have herd acetone works on epoxy but I would do a small test and look into it more befor going todo the real thing
Unread 17-05-2011, 08:01
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
I always use a lighter to heat the motor shaft up.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 17-05-2011, 17:36
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
You're probably going to need more heat than a lighter will provide.
Something like a propane torch would probably work better. If you can heat the wheel/shaft up from the side opposite the motor and hit the motor with freeze spray or a continuous jet of compressed air then you should be able to keep the motor cool enough to avoid damage while you're getting the shaft off.
On the other hand, it sounds like you don't care about the motor that much. In which case flame on till you loosen up the epoxy enough to extract the motor. Just make sure to do it in a well ventilated area.
Unread 17-05-2011, 17:56
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
I think they DO care, because they don't want to damage the motor.
The best way is going to be by heat, but lots of it. Either a heat gun or torch (even better) might work.
Also, acetone apparently "loosens" the epoxy a little bit, but not very much.
Of course, the other way to do remove the shaft and epoxy is with a lathe!
Name a problem a lathe can't fix!
Unread 17-05-2011, 18:44
Off hand, I'd say a lathe wouldn't be great for welding two pieces of plate together.
Bet you thought I'd say milling a slot in something, right? But I'm just nerdy enough to know that you can, in fact, mill with a lathe. And you could probably abuse it into acting as an arbor press and half a dozen other things. Welding seemed my safest bet.
Unread 17-05-2011, 19:00
Depending on the lathe, I think you could weld with one. Of course, that would be totally abusing it... And the weld wouldn't hold real well unless you ramped up the force a lathe can exert--and I mean REALLY ramped it up--but in the land of theory, it might be possible.
Now, arc welding, yeah, I can agree with you on. (Friction Stir welding is the type a lathe might possibly be capable of.)
Unread 17-05-2011, 20:46
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Doughnut holes.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 17-05-2011, 20:54
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
We removed a press fit shaft that was glued on with red loctite threadlocker (one of the uses is press fitting) using a propane torch, the motor raised our forklift all of 10,000 Lakes regional without issues.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 17-05-2011, 21:27
DonRotolo's Avatar
Back to humble
FRC #0832
First, the original problem: Heat softens all epoxy. Eventually.
Then, The Lathe: There is no problem a lathe cannot fix.
Unread 18-05-2011, 17:24
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
Just a word of caution: I've heard suggestions for the use of flame and acetone on this problem. Please don't use them together! Any flame in a room with open acetone is begging for a visit from the fire department.
Dr. Bob
Unread 19-05-2011, 21:19
I've attached a picture of what we've done. Oh and we'd like to save the motor and have it fully functional after we're done. The motor shaft is epoxied to the rod.
Name:	Motor Shaft.PNG
Unread 20-05-2011, 00:25
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
If you could cut the rod off to expose the shaft (if you're careful you'll only loose a millimeter +/- a bit)and heat the remaining rod section while cooling the motor with compressed air, the remaining shaft portion could be removed with a conventional gear/pinion puller (the kind that pulls the gear and pushes the shaft, if you push against the motor can you could crush a spacer [yes, I have done that before]).
Better yet, you could heat the shaft before cutting it. That could reduce the risk of motor damage.
