Go to Post I think your robot is lacking in non-threatening, huggable design. - Kevin Sevcik [more]
Unread 17-05-2011, 12:12
Re: Better Battaries for Driver Pratice
Originally Posted by Chris Mormile View Post
Float charging is more commonly known as trickle charging. It is used on High Performance NICD, NIMH, LIPO, and A123 batteries to keep them from self discharging. This method doesn't hurt or damage the battery. where as if you did that with a lead-acid battery it would start to damage it after a while.
Float charging and trickle charging are not the same thing.
You can leave a lead-acid battery on a float charger.
Unread 17-05-2011, 12:54
Gdeaver Gdeaver is offline
FRC #1640
There are deep discharge gell cell batteries in the typical lawn tractor size that will give allot more power for a little larger case. Long run times can be dangerous with thermal issues. Sears sells a wheel chair battery that is not bad. I use the same case size but much more power battery for my power lift equipment. I'm paying 160$ for the good ones.
Unread 17-05-2011, 13:35
Chris Mormile's Avatar
Chris Mormile Chris Mormile is offline
Only1Battman
AKA: Battman
FRC #1676 (Pascack Pioneers)
Team Role: Electrical
Chris Mormile will become famous soon enoughChris Mormile will become famous soon enough
Oh wow. I never knew that there was a difference between the two. The difference is very minimal.
So basically a float charger is the "smart" version of a "dumb" trickle charger. Cool.
You never get tired of building robots. You just get tired from building robots.
Unread 17-05-2011, 13:45
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
Originally Posted by akoscielski3 View Post
Get a new charger...Ours do not take 3 hours to charge ... usually close to 20-30 minutes. Our charger can charge a battery at up to 15 but we usually charge them at 10 or 5. It can also choose what to charge it at, sometimes it chargers at 0.2, but this takes FOREVER to charge them fully./QUOTE]
The reason that you can charge your batteries so quickly is because you have the ability to charge at 2A, 10A, and 15A. When you charge a battery at 15A, it may charge really quickly but it also increases the chance of blowing up your batteries. Plus they are not competition legal. but for driver practice they are probably great.
The reason that you can charge your batteries so quickly is because you have the ability to charge at 2A, 10A, and 15A. When you charge a battery at 15A, it may charge really quickly but it also increases the chance of blowing up your batteries. Plus they are not competition legal. but for driver practice they are probally great.
akoscielski3, how many batteries have you blown? While charging them at 15A may increase the risk of blowing them out if you haven't blown any it's probably a negligible risk. Getting new chargers is so far my favorite solution.
Originally Posted by squirrel View Post
You might try scheduling more practice sessions, and have them be of shorter duration. I don't know how many hours a day you practice, but it must be more than an hour at a time if you're not able to get it done with 10 batteries that each last 6 minutes.
If you have to spend more than an hour practicing, then you might try using the batteries when they're only about 75% charged, and limit them to 4 minutes of operation.
Or schedule a five minute cooling off period after each five minutes of driving.
True, however while we can work around the problem I'd rather find a fix.
The only reason I would hesitate to do that is the first 2-3 minutes of battery life are noticeably the best. The robot moves faster and it's closer to competition settings (2.25 minutes of a fresh battery). I don't like loosing that cream of the crop battery time but it's better then nothing.
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 17-05-2011, 14:50
Jon Jack's Avatar
Jon Jack Jon Jack is online now
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Taking 3 hours to recharge a battery seems way too long. Also, what voltage are you running your batteries down to?
We practice 5 days a week for an average of 4 hours a day. When we practice we try to never let the battery drop below 12.0V at idle. This is usually 1-3 matches depending on the robot and how much power draw their is during a match. By the time we've gone through all 6 batteries, the first battery is ready to go again. We've also found that by doing this we can actually recondition the battery and keep all of the batteries between 12.8 and 13.1V at idle.
Team 1538 / The Holy Cows, 2005-2016
Unread 17-05-2011, 16:05
Depends on the perspective I guess. To a lead-acid battery it's not minimal, it can be the difference between life and death.
Unread 17-05-2011, 16:23
A lot of the damage to these batteries comes from charging them at high temperature. More current makes a battery hotter. If you're force-feeding a FRC-legal battery with 15 amps for more than a few seconds, you're abusing it. It'll most likely treat you badly in return.
Unread 17-05-2011, 16:25
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
We have never blown a battery. I dont believe that we have charged on 15A before.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 17-05-2011, 21:47
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Better Batteries for Driver Practice
Ask Mr. Don Rotolo if you dont believe me. I got my information from him.
He's a liar, I wouldn't believe a word he says!
The batteries remain competition-legal regardless of the charge rate. The chargers are not competition-legal, and are bad for the batteries (see Alan Anderson's comment above)
OK, so the problem is that the batteries are going dead.
The solution is the same as with my laptop computer: When the battery's dead, I plug it in and run off the wall outlet. (Translation: Find a 100A 12 V power supply and run heavy cables to the robot during practice).
(Oh, and Max: Battaries? Sheesh!)
Unread 18-05-2011, 12:07
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
There is another thread on this elsewhere, but the MFRs recommended maximum charger rate is a little under 6 amps for these batteries. You can do higher at your own peril.
Unread 18-05-2011, 12:16
How are the chargers not competition legal ??
2013-Present
2010-2013
Unread 18-05-2011, 12:40
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
you might want to reduce your driving time a bit to allow all of the motors to cool and be sure you don't damage anything. Depending on which motors you are using and what kind of loads they are seeing, you may be generating a lot of heat.
we are using window motors for our lift arm, and even with a gas assist on the lift we limit ourselves to about 8 - 10 minutes of practice time before letting everything cool.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 18-05-2011, 12:44
I do not want to be near a battery that is being over-charged, and I am glad they do not allow this unsafe practice at competition.
Unread 18-05-2011, 13:43
Only1Battman
AKA: Battman
Lightbulb Re: Better Battaries for Driver Pratice
haha. I keep telling everyone on our drive team and anyone who is with us that we need to allow the motors and other electronics to cool. But unsurprisingly no one listens. When we did our driver practice last Saturday, after about 6 batteries i smelled something weird. it almost smelled like burning electronics. But there was no magic smoke. so i went to feel the motors to see how warm they were, and almost burned my fingers. i told everyone that we needed a 15 min break to let everything cool. (which we did) After the break i could see a noticeable increase in performance.
Also we run super shifters with 2 Cims. We drive our robot around in high gear and when we hit the shift button we shift into the lower gear for more precise maneuvering.
If anyone with a good amount of knowledge in electric R/C's knows that when you start heating up your motor(s) they will degrade in performance. Also high mAh batteries will start to heat up they will start provide less voltage and your truck/car will start to go (slightly) slower.
Unread 18-05-2011, 14:44
OK,
Let's get some info straight here and in one place.
1. Our batteries are specified by the manufacturer to be charged at 6 amps or less. Battery life can be significantly increased when charged at 1/10 C or about 2 amps.
2. Life is significantly reduced by heavy loads like an FRC robot drawing currents in excess of 200 amps over a two minute match.
3. Charging at high current on our batteries causes internal heating and the possibility of out-gassing and case failure if the vents do not operate.
4. Our batteries are AGM types and the plates within the cells are not as robust as older technology lead-acid batteries.
5. Excessive heat within the battery causes the plates to deform, leading to internal shorts and a variety of other issues leading to lower battery life.
6. Hot batteries during charge can fool many/most smart chargers into producing damaging voltage/current during the charge cycle.
7. AGM batteries are nothing like NiMH, NiCd, LiPO, Li ION or other types and each requires a specific type of charger. Do not mix chargers and battery types.
Now on to the problem...
You can use a larger battery, the marine type for example. It must be a 12 volt battery of course. The motor heating encountered should be relatively the same with any size battery you choose. If you are interested more in practice then in demo, I would suggest that you stick with the FRC robot batteries for a variety of reasons. One is that the larger battery will be much heavier and while practicing, you will be over compensating for the added weight. Also, the larger battery will be able to better supply current to your motors giving you performance that will not exist in competition. If your robot draws a lot of current then the larger battery will also lure you into a false confidence that the battery will continue to supply enough voltage to prevent the systems from shutting down. Remember that the Crio monitors the battery voltage and inhibits all output when the battery falls below 5.5 volts at terminal voltage. The regulated supplies in the PD fail at about 4.5 volts which cause both Crio and radio reboots. If you want real world practice you need to keep real world conditions.
