Go to Post FRC is about what we collectively make of it. - Tristan Lall [more]
Unread 18-05-2011, 20:11
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
Accelerometer Troubles
Okay so I have an accelerometer wired up to be tested, but I need to find the voltage gains so that we can use applicable units. (G's)
I have searched the history of FIRST's control resources and can only find information about the ADXL335 and ADXL345 chips.
We are pretty certain that we never ordered an accelerometer outside of the kit of parts and cannot figure out which chip this is.
The chip is a small square that says "Accel r0.1" on top, has the x, y, and z outputs arranges in a 3 X 3 hole square and it says "DSI 5008B" in very small text at the bottom.
Please help me find the data sheet so I can get the correct gains.
FRC 1732 (Hilltoppers): Mentor
FRC 2338 (Gear It Forward): Mentor/Alumnus
FRC 4096 (CTRL-Z): Mentor
Unread 18-05-2011, 21:26
Re: Accelerometer Troubles
That's the red board from the 2009 Kit of Parts. http://usfirst.org/uploadedFiles/200...r%20Manual.pdf has a picture if you want to make sure.
The accelerometer is an ADXL335. From the sensor manual: "The ADXL335 can measure +/-3g in each axis. Nominal output is 1.5V at 0g (free-fall), plus 300mV/g."
