Go to Post Engineers talk with math first, and grammar second. It is a fact of life. - Molten [more]
Unread 19-05-2011, 22:52
vincentkee vincentkee is offline
FRC #0687
vincentkee is an unknown quantity at this point
4" vs. 6" + 8" Diameter Wheels
I've noticed a lot of the veteran teams used the 4" diameter wheels in their 6WD or 8WD drive systems.
Is there any significant advantage to using them over the larger 6" or 8" diameter wheels?
And is there any significant advantage to implementing a 8WD instead of a 6WD?
Unread 19-05-2011, 22:57
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: 4" vs. 6" + 8" Diameter Wheels
4" wheels allow you to create a longer wheelbase, since the smaller wheel allows the axles to be spaced apart further.
Additionally, 4" wheels reduce the reduction required from a CIM motor to achieve a reasonable speed. Smaller reductions mean less frictional loss.
They arguably produce faster acceleration, since the wheels have less rotational inertia.
Unread 19-05-2011, 23:04
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
In addition to what Joe posted above they are also lighter and tend to result in a chassis with a slightly lower Center of Gravity.
Unread 19-05-2011, 23:11
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
i really like small wheels, but i like 5 or 6 inch wheels the best. they are large enough to raise the ground clearance above what a 4 inch wheel set would give.
Unread 19-05-2011, 23:17
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
What for? Is there any reason you needed more than ~5." of ground clearance this year?
Unread 19-05-2011, 23:18
JackS's Avatar
JackS JackS is offline
Sideline Observer
no team (EWCP)
JackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond reputeJackS has a reputation beyond repute
Check out this nearly identical thread. If you search around a bit on CD I'm sure you can find multiple threads with this information.
If you are careful when designing your drive for 4" wheels, you shouldn't have a ground clearance problem.
[2009-2014] FRC Team 2791 - Shaker Robotics
Colgate University
'16
Unread 19-05-2011, 23:21
AdamHeard's Avatar
Lead Mentor
See this post I made in another thread for why we like small wheels.
http://www.chiefdelphi.com/forums/sh...6&postcount=74
In 2010 we climbed the bump with 4" wheels.
Unread 19-05-2011, 23:33
AKA: Isaak
Team Role: CAD
i would prefer 5 inch wheels, but settle for 6 inch wheels for several reasons. most of the omni wheels from andymark smaller than 6 inches are very bumpy, also 4 inch mechanums don't exist for FRC. i think 6 inch wheels are the most versatile, and that the tiny benefit of going to 4 inch wheels is not worth the flexibility trade-off.
Unread 19-05-2011, 23:35
Chris is me's Avatar
AKA: Pinecone
When do you ever design a drivetrain for both mecanum and regular wheels? There's flexibility, and then there's being a jack-of-all-trades, master of none.
Unread 19-05-2011, 23:39
JackS's Avatar
Sideline Observer
no team (EWCP)
This thread is useful too.
Colgate University
'16
Unread 19-05-2011, 23:47
Even when two are paired together?
You can get a smooth ride with omnis...
Unread 19-05-2011, 23:51
AKA: Isaak
Team Role: CAD
one reason is nonadrive or octomanium or any other number of names for the same basic mechanical idea, the drives usually use 6 inch mechs and 6 inch traction wheels. i prefer to use a very standard, modular design strategy, with multiple options. there are many more options for 6 inch wheels than any other wheel set. closon, andymark, pneumatic, good omni wheels, mechanum. with 4 inch wheels many of these types of wheels must be custom made. the 6 inch wheel size is the most versatile. and while it is true that some sacrifice is made in order to gain this flexibility, it is such a small advantage that it doesn't really impact performance too much.
I already designed a frame that will accommodate any drive-train. one of the sacrifices of that frame, was giving up 4 inch wheels of any type.
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The 4" dualie omnis on 2175's robot this year gave a smoother ride than 6" omnis we have used in the past IMO. Admittedly they are a bit heavier and are more expensive than a single 6" omni, but the weight and cost both typically are gained back by knocking out a stage of reduction.
Unread 19-05-2011, 23:58
Smaller wheels in octocanums make desired reductions easier to produce.
Unread 20-05-2011, 00:03
Does anybody have mass and moment of inertia data for comparable 4", 6", and 8" wheels?
