Go to Post I'm so conflicted right now. On one hand, you made the same page as a celebrity. On the other hand.... Justin Bieber. - Akash Rastogi [more]
Unread 17-05-2011, 12:38
ProjectZero ProjectZero is offline
FRC #4276 (Vikings Robotics)
ProjectZero is an unknown quantity at this point
PWM speed controllers cheaper than Victors?
Hi guys,
This summer I'm working on an independent project to build a hexapod robot. I've all ready built the frame, attached the motors, etc. I was using 6 Victor 884s, powered by a 12V battery and controlled by an Arduino Uno. Problem is that when I leave school for the summer I'll have to give back the Victors, and they're waay to expensive for me to buy on my own. Does anyone know of any cheaper pwm motor controllers that work similarly? Thanks alot!
Unread 17-05-2011, 12:48
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: PWM speed controllers cheaper than Victors?
How much current do they really need to handle?
Unread 17-05-2011, 12:52
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
This doesn't really answer your question but, have you tried contacting any local teams to see if they have any used Victor 884's or 883's? I know some teams have quite a few sitting around that they may never use.
-Dustin Benedict
Unread 17-05-2011, 14:37
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
In my first few years in FIRST, teams used to use Tekin speed controllers for RC cars. We used to use Bosch drill motors which had pretty similar power characteristics as the CIMs. They might work. The problem is that they weren't very reliable.
Unread 17-05-2011, 17:26
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
1 Amp drivers-
http://www.sparkfun.com/products/9457
15 Amp-
http://www.sparkfun.com/products/9107
Unread 17-05-2011, 20:06
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Both RobotShop and Robot Marketplace have a pretty wide range of speed controllers. Just make sure you know what current you're going to be pulling.
http://www.robotshop.com/brushed-motor-controllers.html
http://www.robotmarketplace.com/prod...lers_main.html
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 17-05-2011, 21:36
DonRotolo's Avatar
Back to humble
FRC #0832
It all comes down to the current requirements. And the cash available, I suppose.
Sparkfun has a motoduino shield that handles two 2A motors for about $25.
You can build one that handles 2 channels of 2.5A each for about $12 - I have the schematic and a PC Board design if you want.
And there are more options, depending on whether you have an electronics junk box or not.
Unread 17-05-2011, 21:37
Woah, thanks everyone. Guess I should have done a bit more research first. I tested today and even when stalled, the motors don't seem to pull more than 0.5 amps, and the typical no/minimal load current is 40 mA. I'm looking to go with nighterfighter's sparkfun suggestions - as basic (and cheap) as option 1 is, it looks like it will do what I need it to. As long as I make certain the Arduino can output a PWM signal in the correct range to control it, we should be good.
Unread 17-05-2011, 22:08
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Originally Posted by ProjectZero View Post
Hi guys,
Just out of curiosity, what design are you using? Most table-top hexapods I've seen use RC servo motors, which shouldn't need external speed controllers, and you get position control for free (unless part of the project is writing the control loops yourself). Larger ones (e.g. able to carry humans around), I imagine, use discrete speed controllers, but those motors are going to pull more 0.5A...
--Ryan
FRC 766, 2015-, Mentor
Unread 18-05-2011, 13:03
AKA: Matt B
FRC #1771 (1771)
Here is the Ardumoto he is talking about- http://www.sparkfun.com/products/9815
I have one, very easy to use.
Don-
Can you post that PCB design and such? I'd be interested in it.
Unread 19-05-2011, 18:26
dudefise dudefise is offline
FRC #2637 (Panthers)
dudefise is an unknown quantity at this point
Sparkfun has a 50A model if you need that kind of power - but its $59..still cheaper than jags/vics...
http://www.sparkfun.com/products/9668
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
Unread 20-05-2011, 00:11
RyanCahoon's Avatar
I've been tempted several times before by the controller you linked to, except that, as near as I can tell, the only control method are the pots that come attached to the board, so some circuit bending would be required, at the least. Also, it appears that it's uni-directional, so the applicability to robotics may somewhat limited, unless you're building a shooter wheel or something similar.
--Ryan
Unread 20-05-2011, 02:19
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
W... As long as I make certain the Arduino can output a PWM signal in the correct range to control it, we should be good.
Yes, the Arduino can do PWM. The thing to keep in mind is what exactly you mean when you say "PWM".
When we use the term "PWM" when we are referring to FIRST robotics, it is usually understood that we are talking about "hobby PWM" specifications. Hobby PWM usually runs at ~50Hz with a pulse width of 1ms to 2ms. This is usually the signal that feeds a speed controller, a servo or a "servo motor" like a Vex motor.
The speed controller, servo etc. contain electronics that interpret the "PWM" signal and then modify the output to the motor accordingly. For example, Victors and Jaguars both put PWM signals directly to motors. The Vic at 100 Hz and the Jag at 15Khz IIRC. The key is, the outputs to the motor go from 0% duty cycle to 100% duty. They also reverse the polarity of the output to control the direction of rotation of the motor.
The Arduino is capable of generating both hobby PWM and 0% to 100% duty cycle PWM. In fact, the later is done natively in the Arduino.
Unread 20-05-2011, 03:01
dtengineering's Avatar
AKA: Jason Brett
...even when stalled, the motors don't seem to pull more than 0.5 amps, and the typical no/minimal load current is 40 mA. ...
Why not just use an L293D motor driver chip? $3.50. http://search.digikey.com/scripts/Dk...=296-9518-5-ND
Or save a buck and use the roughly equivalent SN754410 http://search.digikey.com/scripts/Dk...=296-9911-5-ND
If you need more power, check out the L298D.
I've been using these for years on mini-sumo robots based on the Tamiya Dual Motor Gearbox and Twin Motor Gearboxes.
Jason
Unread 24-05-2011, 16:24
DonRotolo's Avatar
Back to humble
FRC #0832
Sure, give me a day or three to hunt everything down.
