Go to Post By the looks, 1114 has already figured out both #1 and #2. They're still behind 71, who is just about done with their robot for the 2012 season, is getting driver practice for 2011, and is working on their robot designs for the 2013 water game. You're still way behind. - EricH [more]
Unread 20-05-2011, 16:14
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: 6WD vs 8WD
well, as far as i understand, the goal of having the outer wheels raised is to make them act more like omni wheels. for the purpose of the argument imagine all we care about is drive systems with omni wheels on the corners. in a 6 wheel configuration, 1/3 of the weight is on the traction wheels, and there are 2 of them, in an 8 wheel configuration 1/2 of the weight is on the traction wheels and there are 4 of them. so if the goal of having the outer wheels raised is to make them behave more like omni wheels, in that they can scrub sideways with less resistance, then logic supports that an 8 wheel drive-train will be harder to turn, because there are 4 wheels, and they scrub sideways a little bit, and because there is more of the robots weight on those wheels at any given time.
Unread 20-05-2011, 16:42
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: 6WD vs 8WD
In six- and eight-wheel drive systems with lowered wheels, we examine the behavior of each as two or three four-wheel drive systems, respectively. The raised wheel isn't treated as an omniwheel, it's treated as if it doesn't exist.
--Madison--
...down at the Ozdust!
Unread 20-05-2011, 16:57
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: 6WD vs 8WD
... the goal of having the outer wheels raised is to make them act more like omni wheels. for the purpose of the argument imagine all we care about is drive systems with omni wheels on the corners.
You may want to look further into this assumption.
As you raise the wheel (or increase the center wheel drop) you decrease the load on those wheels. Yes, it decreases the sideways slipping force on the wheel, but it also decreases the tractive force in the same proportion. The first point is that it never really behaves like a omni wheel, just as a wheel with less traction.
The second point is that the load drops off across the distance of your wheel dropped (teams range from 1/16-1/4") which makes it hard to tune. I worked with an adjustable drop 6WD for a few years and we discovered that 2-3mm drop was what worked for us as optimum. Outside that sweet spot we began to get significantly different driving performance. We also discovered that a 1/2 day of matches was enough wear on gum rubber treads to get us outside this range. We eventually decided that it was not worth the effort and decided to let the wheel off the ground and allow the robot to rock between the two 4 wheel systems. It was much simpler in the long run and allowed us to apply our resources elsewhere. I know the 2011 kitbot configuration has enough lift to accomplish this.
You may want to spot check with teams to see if all of their wheels are actually on the ground or just really close. How might having one set of corners off the ground affect the logic you used above?
Mark
Brick walls are for other people. - Randy Pausch
Unread 26-05-2011, 12:36
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Re: 6WD vs 8WD
For Logomotion, we had an 8WD chassis with 6" wheels. The four at the corners were "kit" wheels. The four in the center were closely spaced pneumatics with adjustable drop. (I noticed in St. Louis that 330 used the same arrangement). We adjusted the tire pressure and center wheel drop so that the corners were about 1/16" off the floor on a hard surface, and had light contact on the carpet.
We were quite happy with the arrangement. It turned very well, since the pneumatic tires had better traction and higher loading than the corner wheels. It didn't rock or bounce during accelearation or turning since the corner tires were hard. During acceleration or in a pushing situation, all four pneumatics and one set of corner tires were in contact with the carpet. It was very difficult for others to push or turn us.
It was a good balance between the agility of a 6WD with center drop or omnis, and the pushing power of an 8WD with pneumatic tires.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at Standish and West MI in 2016)
FTC 6043 & 7911 (Competing at West MI and Allendale in 2015)
Unread 27-05-2011, 11:38
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
Re: 6WD vs 8WD
eight
See Ya
Unread 27-05-2011, 11:44
Chris is me's Avatar
AKA: Pinecone
Re: 6WD vs 8WD
Originally Posted by Triple B View Post
eight
Why 8?
Unread 27-05-2011, 13:44
all hail Passmore
Re: 6WD vs 8WD
From my experience, the 8 gives you more stability at higher speeds and better predictability of how the robot will handle. We also decreased the diameter of the outside wheels instead of offseting the axle height.
mike d
See Ya
Unread 27-05-2011, 14:57
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: 6WD vs 8WD
mike d
Did you change the ratios to match teh diameter changes, or just allow for the inherent scrub to occur?
Unread 27-05-2011, 15:22
all hail Passmore
Re: 6WD vs 8WD
no change of ratio, just let it ride.
See Ya
Unread 27-05-2011, 16:09
Re: 6WD vs 8WD
Our 2007 "Rack 'n' Roll" robot was a six-wheel drive with no center drop. It had extra-thick tread on the center wheels and it drove like a dream. We never figured out whether the very slight discrepancy in wheel circumference made any difference one way or the other. There was some conjecture that a teeny bit of scrub on the corner wheels might actually result in better turning.
Unread 30-05-2011, 11:47
Blake L's Avatar
Blake L Blake L is offline
FRC #2016 (Might Monkey Wrenches)
Blake L is an unknown quantity at this point
Re: 6WD vs 8WD
Personally, I like 8WD, although my opinion might be a bit biased because I haven't driven a 6WD robot anywhere near as much as I've driven an 8 wheeled one.
This year my team used eight 4" diameter wheels geared 7:1 and I loved it.
Here is a video of us playing with the chassis a week into build season:
http://www.youtube.com/watch?v=inI40uMKuEE
If I remember correctly, the center two wheels are dropped 1/16". We later added another two motors to the drive train which gave us a nice balance of speed and power.
What does it take 6WD/8WD to be successful? TEE Technical Discussion 26 06-05-2010 08:30
pic: Rastogi 8wd Iteration 1.2 Akash Rastogi Extra Discussion 56 05-05-2010 15:16
pic: Sheetmetal 8wd Akash Rastogi Extra Discussion 16 02-05-2010 15:38
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
8WD drivetrain? David Sherman Technical Discussion 16 09-04-2006 17:32
