Go to Post Great people like you both [Scott and Libby Ritchie] make the FIRST community even better! - tiffany34990 [more]
Unread 25-05-2011, 00:35
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
How to use suction, piab p2010
I currently have a piab p2010, that I believe can be used to use the compressor to create a suction for using suction cup grippers. I'm wondering if anyone has any information or experience using this fitting or has any other knowledge on how to use suction cups in FIRST?
link to piab site
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 25-05-2011, 08:14
Re: How to use suction, piab p2010
It's called a Venturi device and works by keeping a constant low flow of air going through it whenever you need suction.
The volume of air required isn't too great, but you wouldn't be able to use dozens of them at once.
Plan on having your compressor run while you use it.
The Venturi device needs to be very close to the suction cup to get/release suction quickly.
It works pretty well for light objects if you can get a good seal around the suction cup (no more than 14.7 psi of force with a perfect fit).
The Venturi device has been given to us in the KOP in earlier FRC years.
The issue has usually been getting the right, properly fitting suction cup for the task, and using it on smooth light objects.
Unread 25-05-2011, 10:33
jamie_1930's Avatar
Team Role: Student
But how do you hook up the hose inorder to achieve this?
2009
2008
Unread 25-05-2011, 10:54
It requires a small 4mm hose that came with the original KOP package.
Compressed air goes in port 1
Suction cup connects to port 2
Name:	PIAB P2010_venturiDevice.jpg
Unread 27-05-2011, 11:34
PS
I dug this up too.
Unread 27-05-2011, 22:34
jamie_1930's Avatar
Team Role: Student
Thanks mark you've been a lot of help
2009
2008
