Go to Post Someone tried throwing out a perfectly good fleece blanket! It even had the quadratic formula on it! WHY ON EARTH WOULD YOU THROW AWAY THE QUADRATIC FORMULA?? - Karibou [more]
Unread 05-27-2011, 08:51 AM
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: PIDController Rotate
No problem Here is the code I have so far if anybody has any suggestions. The way PIDController works is it creates a thread and does the PID calculations and takes care of the input and output for you. But what do I set the output to to cause the robot to rotate? My guess is create a class that implements PIDOutput and do the rotation code myself. If anybody else knows a better way please inform me.
PIDController turn = new PIDController(DRIVE_P, DRIVE_I, DRIVE_D, gyro,?);
turn.setTolerance(0.05);
turn.setSetpoint(angle);
turn.setContinuous();
turn.enable();
