Go to Post Mr.Lavery You Make My Day - Rohith Surampudi [more]
Unread 27-05-2011, 10:38
Greg Shaw's Avatar
Greg Shaw Greg Shaw is offline
FRC #3601
Greg Shaw is a jewel in the roughGreg Shaw is a jewel in the roughGreg Shaw is a jewel in the rough
Victor Probelms
We are having problems withour a victor that controls a chain tower that we use to hang tubes. Right now we are seeing a flashing orange light. It is my understanding that we need a solid green light to indicate that the victor is good to go. We have checked and rechecked the connections for our PWM Cables. any advice would be appreciated.
Unread 27-05-2011, 10:40
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Victor Probelms
Check and make sure that it is plugged into the correct pwm channel. What language is the robot programmed in?
Unread 27-05-2011, 11:05
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Victor Probelms
Flashing yellow indicates no signal. With victors this usually boils down to the PWM cable connection on the Victor it's self. Getting it seated fully, and with the correct orientation, is a bit tricky. Double check that connection first. I have seen that one connection be the cause of failure dozens of times.
Unread 27-05-2011, 11:06
Re: Victor Probelms
You are trying for a Victor solid yellow/orange light while at rest.
Some of the obvious causes:
  • Bad PWM connection
  • Robot disabled
  • Digital Sidecar not connected and powered properly
  • Code not instantiating the PWM output
With a Victor it's usually the PWM cable end that plugs into the Victor that misses the connection inside the plastic housing shroud. If you pull the PWM connect out there, take a look at the pins to see if they are all perfectly straight. Often one or all of the pins are bend by sliding down the outside of the connector recessed and hidden within the housing.
Unread 27-05-2011, 22:03
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Victor Probelms
On rare occasions the cause of the problem is a faulty sidecar output. We've had it happen to us a number of times; try checking the voltage across the signal and ground with a multimeter, and see if another PWM out will work in its place.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 28-05-2011, 13:43
hat_ios's Avatar
hat_ios hat_ios is offline
AKA: Chris
FRC #0610 (The Coyotes)
hat_ios will become famous soon enoughhat_ios will become famous soon enough
Re: Victor Probelms
I was having some of the same issues. Check the male connectors on the PWM that you are plugging into the Victor. If they are bent, that means that you are missing the females in the Victor, gently unbend them and place in lightly and slowly.
