Re: Victor Probelms
You are trying for a Victor solid yellow/orange light while at rest.
Some of the obvious causes:
Re: Victor Probelms
On rare occasions the cause of the problem is a faulty sidecar output. We've had it happen to us a number of times; try checking the voltage across the signal and ground with a multimeter, and see if another PWM out will work in its place.
Re: Victor Probelms
I was having some of the same issues. Check the male connectors on the PWM that you are plugging into the Victor. If they are bent, that means that you are missing the females in the Victor, gently unbend them and place in lightly and slowly.
