Go to Post Enjoy doing what you do. If you enjoy your life, what you're doing in it, and how you're living it, then what other people say or think doesn't matter. - Beth Sweet [more]
Unread 28-05-2011, 09:19
Jogo Jogo is offline
FRC #0353 (Pobots)
Jogo is on a distinguished road
Obtaining Velocity from an encoder
As far as I know, the WPI robotics library still has a glitch in that it cannot calculate the velocity from more than one encoder. So, I want to write manual code to calculate velocity.
Is the code in the picture sufficient, or should I be doing some averaging or some other way to get rid of noise? Note that it is just a quick mod of the example code.
Unread 28-05-2011, 09:28
Re: Obtaining Velocity from an encoder
It depends on what you intend to do with the rate signal.
Have you cast your vote here yet ?
Unread 28-05-2011, 09:40
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
http://www.chiefdelphi.com/forums/showpost.php?p=1024424&postcount=54 got me through the 2011 season. It patches the bug in LV by not using the broken channels.
Also - You can change the direction of shift registers by right-clicking and hitting "change direction", to make it go from left->right instead of left<-right (just a neatness tip)
Kettering Motorsports
Unread 28-05-2011, 22:38
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
I think you mean turning the feedback nodes into feedforward nodes (they do the same thing, they just have reversed input/output positions). Shift registers are something different (the nodes on the outside of the while loop that passes data between iterations)
Unread 29-05-2011, 00:02
It's misleading to use the term "feedforward node" to describe this.
It's a Z-1 operator.
Feedforward has a different meaning in control theory.
Unread 29-05-2011, 15:19
FRC #0353 (Pobots)
Thank you, apalrd for showing me that workaround. That'll do. And thanks, the left->right feedback is much neater.
