Go to Post One of these years, the game piece will be an actual red herring. - Taylor [more]
Unread 28-05-2011, 11:53
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Rivet
How do I add rivets to my model?
Unread 28-05-2011, 12:16
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: Rivet
Do you already have the Rivet cadded?
Unread 28-05-2011, 12:53
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
Re: Rivet
Cad the rivet then add it in assembly. If you want a short cut then you could incorporate it into the the part and then do a linear pattern. That is, if your model has a pattern of rivets.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 28-05-2011, 13:40
lemiant's Avatar
the Dreamer
AKA: Alex
Re: Rivet
So there is no design accelerator rivet?
Unread 28-05-2011, 13:46
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Smile Re: Rivet
Given that you posted this in the Inventor Subforum, I can tell you how to use a Design Accelerator for this. The advantage of Autodesk Inventor, in my opinion, is not the aesthetic advantage (which I'll admit I'm quite fond of) but the incorporation of Design Accelerators to help with fluidity in the design process. If you CAD the entire robot, don't worry about designing your own sprockets, bolts, chain, rivets- anything. Inventor will do it for you and give you calculations based on the size of the accelerator in your design.
For a riveted connection, you're best off opening your assembly and navigating to the "Design" tab in the Ribbon-bar. On the left side of the Ribbon, you'll find "Pin" , next to "Bolted Connection". When you click on pin, make sure you're set to cocentric (very important). Then, simply click the start plane, hole, and end-plane. You'll then need to select your rivet diameter. On the right side of the window, click on pin, and just choose the most appropriate one.
I advise that you save the rivet choice and diameter (bottom of the window).
Hope this was clear enough for you. Again, another option of course is to CAD the rivet manually and Insert constrain it into each and every hole. It all comes to a matter of personal preference.
Good Luck!
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 28-05-2011, 17:03
lemiant's Avatar
the Dreamer
AKA: Alex
Re: Rivet
Good Luck!
Thanks, Just a couple of questions: Which type of pin (secure, joint, etc.)? Which content center pin looks like a rivet (I cannot seem to find one)?
Unread 28-05-2011, 17:08
M.Wong's Avatar
M.Wong M.Wong is offline
FRC #0503 (Frog Force)
M.Wong is a jewel in the roughM.Wong is a jewel in the roughM.Wong is a jewel in the rough
Re: Rivet
If you downloaded the Inventor Content Center Libraries during installation, there should be a ton of different rivets in the Content Center. Metric and Standard of course.
Unread 28-05-2011, 17:20
lemiant's Avatar
the Dreamer
AKA: Alex
Re: Rivet
There are lots of pins, but none of them look like pop rivets
Unread 28-05-2011, 19:13
AKA: Mathew Simon
Re: Rivet
Personally, I just use the plainest STD pin. Generally, I use 0.125" holes and 0.115" pins. It's not perfect, but it serves the purpose and some. It's easy and efficient to accomplish.
Mathew Simon
CAD/Design
Unread 28-05-2011, 23:47
lemiant's Avatar
the Dreamer
AKA: Alex
Re: Rivet
At the moment, I am using "By hole", to place the rivets. It works on the original hole, but not any any of the ones created by a pattern.
