Go to Post Don't forget Morgan Freeman will be at champs. Maybe he and Will are gonna freestyle it! - Nuttyman54 [more]
Unread 29-05-2011, 18:26
GaryVoshol's Avatar
Cogito ergo arbitro
paper: MARC 2011 Rule Changes
Thread created automatically to discuss a document in CD-Media.
MARC 2011 Rule Changes by GaryVoshol
Unread 29-05-2011, 19:25
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Re: paper: MARC 2011 Rule Changes
Looks good and I think should should really improve the game.
I have a question and a clarification. First, does the backup robot need to be played or just to win the event. For example, if you lose the first quaterfinal match, do you need to play the backup?
Secondly, the top seed gets 1st overall pick, 1st pick in the second round and first pick for backup? Sounds like an awfully huge advantage to the top seeds and a nearly impossible task for the lower seeds.
Unread 29-05-2011, 19:44
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
I agree. I hate to be offensive, but that rule change makes no sense whatsoever.
On another note, i don't understand your "penalty-based" minibot scoring system. does this mean if Red's minibot gets first then Blue's team get 4 penalties and Red gets 18 points? or Blue just gets -18 points?
Confused,
Disappointed,
-duke
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 29-05-2011, 19:49
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Originally Posted by Duke461 View Post
I agree. I hate to be offensive, but that makes no sense whatsoever.
Confused,
Disappointed,
-duke
From what I read of it, it looks like the penalties are just there because otherwise they would have to go into the FMS and modify the software itself-its just considered penalties as an easier way to alleviate the score, meaning that in order for them to not change the FMS software, they just consider the point differential as a penalty.
Unread 29-05-2011, 19:50
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
Ah. I was just finishing my editing of my post where i added that possibility into my question when i saw your post
Makes sense.
One more question, if for some reason the backup team you select completely breaks down before any of the matches, are you allowed to get another backup/not have to play your current backup? Also, is it one elimination match per round?
Thanks,
-duke
Unread 29-05-2011, 21:40
GaryVoshol's Avatar
Cogito ergo arbitro
The backup bot will need to play at least once in the Elimination round. Yes, that means if you lose your first match, it must play in your second match to ensure that the backup bot has played. So choose wisely, don't pick a backup that isn't running. But at least you've got a choice; you aren't assigned a backup based only on the rankings.
The serpentine draft (1-8, 8-1) tends to balance the levels of the alliances. However in some tournaments, the 8th alliance gets a big advantage, because picking two nearly-top tier partners in a row is such a benefit.
IRI has had 1-8, 1-8 draft and pick your own backup for years. We decided to give it a try at MARC this year.
Assigning penalties is the mechanism for reducing the Minibot Race bonuses - we knew it would work without having to mess with the scoring software.
(since 2004)
Unread 29-05-2011, 22:07
XaulZan11's Avatar
I understand the rationale of it, but given the depth at MARC I think the 1v8 match up will be 2 elite robots, 1 good robot vs 2 good robots and one that can barely score. Then, after 8 loses the first match, they need to play the 32nd best team at the event. IRI has the backup bot selection go 8-1 and doesn't force teams to play the backup. I guess you just have to do anything possible to avoid the 6-8 seed.
Unread 29-05-2011, 23:18
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
exactly. Im ok with these rules; but, In a year where the 1 and 2 seeds completely dominated, we're going to give them a boost by letting them get an earlier 2nd pick? oh well. MARC will still be tons of fun nonetheless. Can't wait to go.
Unread 30-05-2011, 08:47
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
I disagree. In a year where at events, there was depth, the first and second seeds were in no way guaranteed a win or finals.
217, 469, 201 lost to 74, 3098, 548 (1-8) in quarterfinals at the Michigan State Championship.
1771, 1114, 294 lost to 469, 610, 188 (1-4) in semifinals in Galileo.
3539, 118, 303 lost to 155, 229, 1023 (2-7) in quarterfinals in Archimedes.
1241, 2056, 368 lost to 987, 968, 51 (1-5) in semifinals in Curie. 5 went on to Einstein.
1678, 2415, 1732 lost to 217, 1503, 25 (2-7) in quarterfinals on Newton. 7 went on to Einstein.
At a very deep event, the 1st and 2nd seeds are by no means a lock for finals. My examples are only a couple of these.
My personal views on serpentine is that, at a deep event with "straight" drafting, it will be fun to see some powerhouse alliances that face good competition. However, serpentine allows upsets to happen much easier - and that's very exciting!
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
Unread 30-05-2011, 10:34
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
I like most of the changes just one clarifications though. What did the frog force feeder do at troy?
Also I don't like the new draft system, the 1vs8 match will be the best, second, and 17th best robot against the 15th,16th, and 24th. This might work at IRI, where there are probably 30 some amazing robots. While Marc is becoming very competitive this gives a huge advantage to the first seed. Especially when the back ups need to be played by the loosing alliance.
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
Unread 30-05-2011, 11:21
P.J.'s Avatar
P.J. P.J. is offline
Proud Member of the Herd
P.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond reputeP.J. has a reputation beyond repute
At Troy, the Frog Force feeder (and I have seen other feeders do this, so not to just put the blame on him) threw a tube, misjudged the angle, and knocked off the triangle of the opposing alliances logo. In the old rules, this was a red card (I believe)
Unread 30-05-2011, 13:53
jmiller48167's Avatar
jmiller48167 jmiller48167 is offline
Mentor, Volunteer, Judge, and Dad
AKA: Mr. Jason Miller
FRC #0033 (Killer Bees)
jmiller48167 has much to be proud ofjmiller48167 has much to be proud ofjmiller48167 has much to be proud ofjmiller48167 has much to be proud ofjmiller48167 has much to be proud ofjmiller48167 has much to be proud ofjmiller48167 has much to be proud ofjmiller48167 has much to be proud ofjmiller48167 has much to be proud ofjmiller48167 has much to be proud of
Actually their human player tossed the tube over the wall and it hit the minibot pole bounce back and scored on the bottom rack for the opposing alliance. Since this is a penalty and red card it is NOT what they planned to do. It was an unfortunate no brainer for the ref's.
The ref's don't like all the rules we just have to enforce them.
Cad Mentor, Dad, Uncle, Volunteer
Unread 30-05-2011, 14:03
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
I agree, at IRI, 1-8,1-8,8-1 works because the depth is amazing... I don't believe we have the same firepower as IRI... But I guess we will see what happens..
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 31-05-2011, 16:18
Steve Ketron's Avatar
Steve Ketron Steve Ketron is offline
FRC #1528 (MTR (Monroe Trojan Robotics), formerly iPirates)
Steve Ketron is a name known to allSteve Ketron is a name known to allSteve Ketron is a name known to allSteve Ketron is a name known to allSteve Ketron is a name known to allSteve Ketron is a name known to all
First off, there are several instances were the best robot/s are not the #1/2 seeds. A lot of this falls into the luck of match scheduling. Typically in these cases, the later draftees (2-8) turndown the invite to pick there own alliance. The MARC TEAMS might not have the glory of all those IRI teams but we always compete at the highest level. Now with the reduction of the minibot race points, more teams are evenly matched with the so-called elite teams.
But some information to support our cause:
41 of 48 teams from Michigan: 6 of top 10 teams
13 of top 20
18 of top 30
25 of top 40
Michigan District titles: 13
District Finalist: 15
MSC Champs: 3
MSC Finalist: 2
Regional Finalist: 1
World Divisional Title: 1
World Divisional Finalist: 1
Like I said, I believe this is going to be a very competitive event. Teams just have to do a little more scouting to compete.
