Go to Post There's no feeling quite like that one you get when you're behind the diamond plate controlling a metal beast that you've put your blood (literally), sweat (more literally), and tears (probably literally) into, and it working. Undescribable. - scali [more]
Unread 29-05-2011, 20:28
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: How to Save the World...
Originally Posted by akoscielski3 View Post
I don't think i would want to drive on glass when wet though :$ I think they need to think about that, and lightening striking the roads.
If it was easy, it would have been already done. The point is we are challenged to solve the problem.
A task too hard, time too short, resources too little... yet people find solutions....
Ed Barker
Unread 29-05-2011, 20:51
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Man, if only we had something like that in a High School robotics program...
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 31-05-2011, 20:21
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
I recall saving a cheerleader to be the requirement to save the world. Can anyone confirm this? If so, we just need to find the cheerleader.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 01-06-2011, 08:58
Back after 4 years off
FRC #5279
I laughed.
I can't view the site because I am at work. Based on the posts it seems that the proposal is to replace highways with solar panels, is that correct?
I remember a while back reading an artical that proposed running piping through the asphalt to take advantage of the heat absorbed by the black top, that solution would eliminate the problem with drivin on glass.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
