Re: cRio limbo
There are several possible causes depending on the error messages and don't forget what the cRIO status lights are doing either.
You can try the No App switch/reboot as Don suggested. This works if it's only a bad or corrupted user program at fault. Another process is to boot in Safe Mode and reformat, followed by a non-Safe Mode reimage, both using the cRIO Image Tool. This pretty much works whatever the cause was as long as it's a software problem. There's also the possibility that metal debris has worked it's way inside the cRIO and is causing intermittent shorts. You fix that by carefully opening and following directions to clean out the cRIO case. Last edited by Mark McLeod : 31-05-2011 at 21:18. |
Re: cRio limbo
I tried to reformat in safe mode, there's just more errors. I'll try to try the no app switch soon.
Re: cRio limbo
Without knowing what the error text says, I can only give general info.
The cRIO has to change IP addresses and reboot several times during the formatting operation. Various computer ethernet cards and drivers respond to this very differently. For many computers, you just cable them and format. Others will reconfigure their network adapter each time the cRIO reboots, and still others will start trying to use the wifi or other network options at some step of the process. For best results disable wifi and any additional network configurations on the computer. Instead of direct cabling the laptop and the cRIO, plug both into a router or switch, such as the blue Cisco. Setup the Cisco to the same IP address as the laptop if it isn't already. The switch will not reboot during the format, and will keep the laptop from reconfiguring its enet when the link goes away. Then follow the safe-mode formatting instructions. If it fails, please copy the errors and include them in your next post. Greg McKaskle |
Re: cRio limbo
I tried the no app, but it I didn't see a difference. I only get error numbers the first attempt after the cRio boots up. The second and beyond gets me this "The cRIO IP address (10.31.69.2) is unreachable. Ensure that one of your computer’s network adapters is on the same subnet." But again, this goes away after I restart it. I normally get error numbers 1, and 60 very frequently, and occasionally I even get a number like 15550, although I couldn't get it today. But they let me bring the electronics board home, so I should be able to respond a lot faster now. Thanks again for your help!
Re: cRio limbo
Sounds like network problems where your laptop cannot communicate properly with the cRIO, so I'd first concentrate your efforts on things that cause those kinds of problems.
The FRC cRIO Imaging Tool will tell you if you're getting through to the cRIO. Check to see what IP address is shown for your cRIO. You can connect your laptop directly to the cRIO port 1 for this test. Do as Greg suggested and turn off wireless, etc., leaving only the Ethernet port enabled. Connect an Ethernet cable between the laptop and the DLink and another between the DLink and the cRIO. Last edited by Mark McLeod : 07-06-2011 at 08:54. |
