Go to Post CAD pictures are cool, but hardware in hand is cooler. :) - ajlapp [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 01-06-2011, 09:05
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: Hibner: Software Testing Via Simulation
Thanks for the answers!
We typically use potentiometers for feedback. Any modeling recommendations for a potentiometer? It seems fairly straightforward to me.
Can you test for equivalent motor command? I.e. I could put the actual robot arm into a know position, say parallel with the ground.....then apply a known PWM to it's motor until it is held in place and not falling. Would this value then be equal to the equivalent motor command to simulate gravity??
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 01-06-2011, 11:00
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
I don't do anything to model potentiometers - I just use the angle calculated by the simple model as my sensor feedback. I do usually use a noise model (if you have your cRIO handy, use the noise testing method in my last post. If not, 2 degrees of noise is a good starting point).
If your arm is already built, that is exactly how we do it. You only need to do the test in one position, and the rest is proportional to the sine of the angle from vertical. If you do the test with the arm horizontal, then the equivalent motor command is EquivAtHoriz * sin(angleFromVertical). If you look at the arm model example, this is exactly what was done.
If you don't have the arm already build, you can do some rough calculations to get a good starting point. If you don't feel like rough calculations, using 0.2 seems to work pretty well for getting your software debugged.
